Visitors: 114
Total: 114
05: Event Calendar
06: Pictures
71: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wire harness
Wire harness
Post Post subject: Wire harness
Posted: Mon Feb 25, 2008 01:47 PM
Hey guys,
I'm going to replace the whole harness in my Baja as soon as I drop the body back onto the pan.
I'm converting to altenator so what year harness should I get Question
My manual covers 66-69 and the wire diagram shows generators only.
Post Post subject: Re: Wire harness
Posted: Mon Feb 25, 2008 02:19 PM
Stick with the 66 harness, its alot less wiring and extra crap to hook up. Its easy to convert the harness to an alternator, all you have to do is run the post terminal wire from the alternator straight to the positive on the battery, and then the wire that goes to the 61 terminal on the regulator goes to the push on spade terminal on the alternator. Thats it.
Posted: Mon Feb 25, 2008 02:26 PM
Well, my concern was mainly around the elimination of the regulator under the rear seat since the altenator has it built in. I didn't want to have a break in the harness. I figured later year models w/altenators wouldn't have that splice.
Thanks for the info Bug-Z.
Posted: Mon May 26, 2008 04:13 AM
Well guys and gals, I've completed my chassis and dropped the body down, complete with a 3" lift.
Now I'm ready for the harness.
I'm looking at Watsons-streetworkks for $350 w/fuse box.
I know most of you did your own but I don't have that kind of time
What do the rest of you think?.
Any other ideas/places?
nukeworker
nukeworker
Posted: Mon May 26, 2008 06:03 AM
I used Streetworks. I never wired a car before in my life. I was able to get it right about 95% of the way. You have to figure a few things out for yourself (like the blinker switch). I will help you any way I can. The guys in the electrical forum of shoptalkforums.com were life savers. Couldn't have done it with out them. That said.....everything works great on my car. I'm very proud of the fact that I did it myself. It looks good too. Nice modern fuses and upgradable.
Posted: Mon May 26, 2008 06:09 AM
It is a great harness I have installed three of them in my cars. You will be very happy. I get all my street rod and custom stuff from them.
Posted: Mon May 26, 2008 07:07 PM
Cool deal. I'm convenced.
Thanks guys... Very Happy
No new posts VW Volkswagen & Baja Bug General Discussion Which wire is which - to the coil? 12 SandRacer 5684 Re: Which wire is whic...
 Fri Feb 29, 2008 07:29 AM
No new posts VW Volkswagen & Baja Bug General Discussion Ford 2.3 Wire Harness 9 coreyvdg 4945 Re: Ford 2.3 Wire Harn...
 Mon Feb 05, 2007 08:25 PM
saltyslug View latest post
