Latest: Nrd123
Overall: 3578
Visitors: 132
Total: 132
01: Pictures
39: Event Calendar
47: Event Calendar
58: My Account
59: Event Calendar
65: My Account
67: Event Calendar
68: Event Calendar
69: Pictures
70: Pictures
111: Event Calendar
125: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Steering Coupling question
Post Post subject: Steering Coupling question
Posted: Mon May 19, 2008 03:12 AM
Hey guys. Just finished mounting the body back to the pan with the lift kit in between. Very Happy I started cutting away at the hole for the steering column, did a mock-up mount of the column and noticed that she was a bit short. Confused I could make up the difference by sliding the clamps but I don't get good vibes from that approach. Shocked
What I was thinking was adding a second steerling coupler to fill the gap. The thickness of that should suffice.
What do you guys think? or more importantly, what did or would you do?
Post Post subject: Re: Steering Coupling question
Posted: Tue May 20, 2008 06:07 AM
With the lift the angle will be off. A trip to the bone yard should produce a useable u joint and shafts. Lastest Rage sells a u joint and stub splines for about $40.00.
Posted: Tue May 20, 2008 06:23 AM
I kept the column in the stock location and went the u-joint route. I used the u-joint assembly from a super beetle. If you get a spare column just use the top bearing on the bottom because the stock column has no bottom bearing.
Posted: Thu May 22, 2008 09:56 PM
perrib,
Where did you get 'em? You gotta a link?
Posted: Thu May 22, 2008 11:12 PM
Chirco Tuscon AZ 800-955-9795 and Karls Kustom Mesa Az 480-827-8051 usually stock them. Chirco has an online catolog.
Posted: Fri May 23, 2008 02:24 AM
I looked at Chirco (and others) before I asked.
The only thing I saw was: www.chircoestore.com/c...ts_id=4186
Is that all I need. I know NOTHING about SB's so will this fit my 68' colum and gear box?
Posted: Fri May 23, 2008 04:14 AM
You may have to call them. "They are universal". You may have to drill the shaft larger or shim it smaller. Either way use plug welds to hold the stubs to the tubing. Its the 5/8" 36 spline u joint AC 425020 and stub spline
ac 425160. They may not be using the same#'s. I got the #s from Pacific Customs.
Posted: Fri May 23, 2008 04:22 AM
Mooreparts.com also has them. Give Chiro a call first, thier customer service is good. I never had anything shipped from Karls just walk in but they are good. Pacific Customs has terrible customer service. I ordered a couple of parts and told them only ship them in one box, do not ship from multiple locations. When it arrived in two boxes I called and they basically said take a hike, its thier shippers fault.
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 7658 Cheap DIY electric pow...
 Fri Nov 06, 2015 02:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 6785 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion looking for shocks and steering dampner 2 Rigger 1505 looking for shocks and...
 Tue May 13, 2014 12:30 PM
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2413 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5014 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
