Latest: rcwtony
Overall: 3607
Visitors: 77
Total: 77
08: Event Calendar
29: Event Calendar
71: Home
77: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- chrispy56's 64
chrispy56's 64
The following users give thanks for this topic Anonymous - Sun Mar 01, 2009 09:04 PM
chrispy56
chrispy56
Post Post subject: chrispy56's 64
Posted: Tue May 20, 2008 08:20 AM
finally took some pics. currently working on the cage. i really need to get the fuel tank, and rack and pinion so that i know where to leave room to install and allow for tie rod movement
my buddy's 2.3 conversion, he got married and had a kid. seems like his project is on hold for now, but it is so close to being done. you like his custom radiator reservoir
Post Post subject: Re: chrispy56's 64
Posted: Tue May 20, 2008 10:04 AM
He needs to move the radiator, the hot exhust coming out in front of it might give you some over heating problems.
chrispy56
chrispy56
Posted: Tue May 20, 2008 05:09 PM
it is not as close as it looks in the picture, there is also a fan there that you cant see in this picture either. he's been driving it with no problems(yet, it is a ford) its just not legal yet.
Posted: Wed May 21, 2008 07:31 AM
it's the same engine I have. Get the 2.3 mustang oil pan or ranger truck oil pan (Not the cast aluminum pan). It will put your sump next to the bell housing and you will get more ground clearance, than you would if you had a VW engine in it.
Work on the wiring Smile
Posted: Wed May 21, 2008 07:38 AM
Ford for the win!
Looks nice
chrispy56
chrispy56
Posted: Wed May 21, 2008 08:17 AM
that motor came from a mustang II (1975, i think) and the oil pan is super low- the lowest point on his car, and he is still lost in his wiring.
Posted: Wed May 21, 2008 09:15 AM
the mustang II is the pinto mustang you need to find one of the new ones. after the II sorry about that, I forgot about them. Look at the pan on my baja for what you want.
Posted: Thu May 22, 2008 02:31 AM
chrispy56 wrote:
i like it..... Cool
chrispy56
chrispy56
Posted: Tue Jun 10, 2008 03:27 AM
first cut towards rack and pinion installation.
npetric
npetric
Posted: Tue Jun 10, 2008 02:56 PM
Sweet ct70's in the background! Cool
67 a-arm baja honda 3.0
chrispy56
chrispy56
Posted: Wed Jun 11, 2008 01:19 AM
yeah. those things are awsome
chrispy56
chrispy56
Posted: Sun Jun 15, 2008 01:09 AM
some more progress
Posted: Sun Jun 15, 2008 01:58 AM
YIKES! You cut up the frame head? That's a major support area that I would shy away from big time. Glad to see some plating to beef it up again. Is that some thing you "have" to do to install a r&p?
Looking good.
I to like the CT70's. In fact I still have mine from when I was a lad. Mine's metalic green, 1970's version and she still runs. I take her around the neighborhood now and then.
chrispy56
chrispy56
Posted: Sun Jun 15, 2008 02:50 AM
This is the only way without reconstructing the whole front end out of tubing. The rack and pinion must be low enough in the car to make the tie rods parallel with the ground at ride height. I am aware of the support issues and with probably end up over doing it.
chrispy56
chrispy56
Posted: Wed Aug 06, 2008 02:13 AM
i think i have cut enough out for the rack. just a little bit more on the top center to allow for the steering linkage. then plate off the remaining open areas like i did the first one.
No new posts New Members chrispy56 6 chrispy56 2937 Re: chrispy56
 Fri May 02, 2008 11:06 PM
joxracing View latest post
