Latest: hulkbaja
Overall: 3594
Visitors: 118
Total: 118
07: Event Calendar
11: Pictures
12: Event Calendar
31: Home
41: My Account
48: Event Calendar
57: Pictures
85: My Account
86: Event Calendar
96: Home
112: My Account
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- MeanGreen's Baja Build.
meangreen
meangreen
Post Post subject: Re: MeanGreen's Baja Build.
Posted: Tue May 20, 2008 05:54 AM
yea,it turns the rite way,and yes i have found an adapter for it at kennedy,it says it for a 2.5 jeep,but they are the same engine....and they offer a 60 degree chevy v-6 adapter which will bolt rite in,i know becuz 1 of my s10 had a blown 2.5 in it so i put in a v-6 2.8 into it no probs.so eather one would work perfect.
Posted: Tue May 20, 2008 10:24 AM
All engines turn the same way...with a note: Corvair and some hondas turn the wrong way. But corvairs turn the same way as all chevy engines it's just you mount to the trany from the nose and not the tail of the engine.
meangreen
meangreen
Posted: Tue May 20, 2008 06:54 PM
my thoughts x-actly az....i just didn wanna run my mouth bout sum'n i was not perfectly sure of.
meangreen
meangreen
Posted: Tue May 20, 2008 07:39 PM
well,hbere are a cuple pics of the engine,they arnt very good,my cheapy camera is already acting up......
so,i was just gunna throw on a new head gasket/intake/exuast gasket and run it,but i was looking on the net last night and found out that there is certain hond rods u can install in this engine,and have your crank offset ground that will make it rev really quik so i think i am gunna look into that along with getn the puter programmed and a header/cam upgrade...should put me at about 140-150 hp fer WAY less than a vw engine would cost to get that much power..any thoughts ?
meangreen
meangreen
Posted: Tue May 20, 2008 07:48 PM
i really like this engine becuz,it will fit in the bug and i wont have to clearance the fire wall for the dizzy like on most water-pumper installs,and its narrower than a v-dub oviusly,its gunna sit about 4 inches bellow the bottem of the luverz,duzn hang as low as a v-dub and its only gunna be about 4 or 5 inched longer installed than a vw with a trimill.
planenutz
planenutz
Posted: Tue May 20, 2008 09:13 PM
Yeah. Are you prepared to face the wrath of your aircooled bretheren? Kidding! Wink
It looks way cool. If/when my 1600 ever goes to that great Baja area in the sky I think I'd do a water pumper with A/C. (did I mention it's supposed to get 104 here today?)
planenutz
planenutz
Posted: Tue May 20, 2008 09:17 PM
How much is the weight difference tween this and a VW? Where are you planning on mounting the radiator?
DutchBug
DutchBug
Posted: Tue May 20, 2008 09:30 PM
Looking good. I paid a lot for mine but hey, mine is ready...
Except fot the bumpers, paintjob, interior, dash, uhm , lots more.
Oh, well, it's driving.
Oh, and Empi sucks I guess. I have a bobcat wich didn't fit nicely and rusts like hell, but it is cheap so I'll just buy a new one when it's done Smile
meangreen
meangreen
Posted: Tue May 20, 2008 09:34 PM
well as far as weight diff goes....i can pic eather the bug or the s-10 engine up and to me it feels like around 100 pounds diff but i dont know fer sure....and the a/c is the rought i'm headed as well....and i plan on mounting the radiator/condencer beside the engine like az has his with dual electric fans and a scoop that covers to all to protect an hopefully help direct the air to the radiator....but if i donjt like the wya that all looks i mite do some sort of spoiler or sumn.
meangreen
meangreen
Posted: Wed May 21, 2008 05:23 AM
ok,so i jerked the head off the 2.5 and found....... Shocked .......no ring gruve,perfect crosshatch pattern on the cylender walls.....WOW thats GREAT i thought,but i was sure it was to good to be true,so i pulled the oil pan,and.....there was...no endply,the bearings were all tight,and the engine is tight to turn with the head off,not to tight but it feels like a new engine kina tight.............so i am real happy and think i mite just run it...instead of the honda rod's,cam,and all that good stuff....now i am just planing a header a puter upgrade and some throttle body upgrades.
meangreen
meangreen
Posted: Sat May 24, 2008 06:58 AM
ok,progress has been at an all time low,work has realy picked up this week and less it rains mite not slow down for a while...but i did get my last coat of paint on the car and will hopefully get the clear on tomaro night....i think it looks realy good,the pictures dont do it justice,and i only have $80 in the paint so i caint complain...i am trying to decide on a radiator setup,i am gunna run a 4.3L v-6 chevy ratiator with the 2.5 cuz i think it'll help keep temps down...i have almost made my mind up that i wanna run a spoiler/win type setup and was wondering if anyone has a pic of a car that has the radiator below the rear glass that does not obstruct the rearward veiw ?
Posted: Sat May 24, 2008 01:51 PM
meangreen
meangreen
Posted: Sat May 24, 2008 05:09 PM
Shocked Shocked Shocked Shocked Shocked WOW that purple one is bad A$$ i just dont know how that would look on a baja....thanx 1fasthoe az's looks real clean and all but im worryd about rocks and other debre hitting the radiator.....and az,does it kool well in that position ?
GOTDUNES
GOTDUNES
Posted: Sun May 25, 2008 04:36 AM
meangreen wrote:
ok,i have a lil' money put back,and have decided its time to build another baja..so what u will see is a 71' bug.....i gave 200 bucks for this one and 10 others....here is what i started with.....
I'm very very jealous Evil or Very Mad Its hard enough to find a doner around these parts and if you do, lets just say $200 is a down payment.
meangreen
meangreen
Posted: Sun May 25, 2008 05:08 AM
u gotta be kidn me....i know where at least 50 old bugs are around these parts that are in decent shape fer under 600 bucks...i got rid of my green one u see in my avatar fer the equivelent of $1000 and it had new window rubber,bus trans,nice 31's in the back and 235's up front,with cuztom 3" lift spindals with s10 roters that i built,a master cly. outa an old chevy,scat steering wheel,hurst drag-fast shifter,and a decent sony sterio system.bugs just dont bring much round here.at this point im just real proud of my engine,2.5 rebuilt fer $40,i'v opnly got around $300 in car at this point and thats paint/primer/sandpaper/engine/window rubber/windsheild/and complete gasket set fer the engine.and i'll only have $425 if i run the BMW wheels i bought that fit s10 pattern lugs,they are 17's and have good 235's on em,they arnt what i'd like to run on it but i already have them,they have GREAT tires,and they fit so i think thats what i'll usr fer a while.heres a pic of em'
i think i'll getm powder coated black first
5 Admin_AzBaja 7860 Baja Bugs on Wiki need...
1568 mufasavnvmc 1032982 Re: what did you do to...
285 MusicManiac 249394 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 863 FREE VW BAJA'S
0 Northmountainauto 1982 Shop Baja
