Latest: jor_dang420
Overall: 3597
Visitors: 110
Total: 110
03: Pictures
08: Event Calendar
22: Event Calendar
31: Event Calendar
50: Pictures
57: Home
65: Event Calendar
73: Event Calendar
79: Event Calendar
92: Pictures
103: Drivers
1 2 3 4 5 6 7 8
Post Post subject: AZ350X suspension/brake upgrade- call it DONE
Posted: Sun May 18, 2008 06:11 PM
It's time (finally). I'm headed out to the garage right now to start tearing the front and rear end apart.
FRONT MODS-
Warrior +6 beam
"Tweed" 2 1/4 x 1 chromoly front trailing arms
SACO billet front hubs with cross-drilled rotors
SACO rack and pinion steering
Wilwood 2-puck calipers
Pro-comp 10" (or 12") shocks with external reservoirs
REAR MODS-
Chenowth chromoly tubular 3x3 arms (with fresh hammered silver powdercoat) Wink
SACO billet rear hubs with crossdrilled rotors
Wilwood 4-puck calipers
I have a proportioning valve and Jamar linelock to install as well...
Will have to work out which shocks are going where when I get things going a little bit. Probably going to require some cage re-work and inner fender mods to get the upper shock mounts set up right...
The current configuration is-
FRONT:
stock-width cut and turned LP beam
stock arms
drum brakes (not hooked up- left front doesn't even have a backing plate)
REAR:
boxed-style heavy duty (thick) 3x3 arms
930 CVs
bus KYB shocks
aftermarket 4-lug disc brakes with wide-5 adapter plates
Gonna be a project, but I can't wait until it's DONE!!!
I'll try and take pics along the way.
ditch68
ditch68
Post Post subject: Re: AZ350X suspension/brake upgrade
Posted: Sun May 18, 2008 06:15 PM
Yes, photos - I will be doing the 6" over beam too.
I'm sorry again about the Chirco pickup...
Jeff
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
Posted: Sun May 18, 2008 06:36 PM
Jeff
Hey man- it's all good. Like they say- "defecation occurs" Laughing
planenutz
planenutz
Posted: Sun May 18, 2008 06:49 PM
So you'll have it done by next weekend? Wink
Gonna be a mean machine! (well, moreso than it is now!)
Any plans for the old 3x3 arms and rear discs? Cool
Posted: Sun May 18, 2008 07:19 PM
I wish! I'm hoping a month, but there's gonna be some cage re-working and such that's beyond my capability that I'm sure will slow me down some!
I hope so... Cool
Umm- they're gonna be for sale as soon as they're off the car. I know a couple guys are interested, but in all honesty, I gotta try and get top dollar for them or the CFO's gonna fire me. Laughing
I'll have an ad up for them as soon as I can, with pics and price.
planenutz
planenutz
Posted: Mon May 19, 2008 03:14 AM
Are you going with coilovers on the rear or staying with torsions? Is there a rule of thumb for 3x3's for using coilovers vs torsions?
It's Ok about the $$ on the old parts. I have so much to do now on mine (that I'm not doing... Embarassed ) that I had better get it running again first! Laughing
Posted: Mon May 19, 2008 06:13 AM
I'm staying torsion- you can do either with 3x3's. I've got some Pro-Comp bypass shocks with reservoirs that I'm going to run. Some people even switch to coilovers AND still run torsion bars, with no preload. So, there's a lot of different ways to skin this cat. Laughing
meangreen
meangreen
Posted: Mon May 19, 2008 07:08 AM
what tortion bars are u running with your 3x3's
Posted: Mon May 19, 2008 07:27 AM
28mm LONG Sway-A-Ways (aka "SAW").
Posted: Tue May 20, 2008 10:50 AM
I'm running 29mm long in my baja with 3x3 arms. you need to goto the sway away sight it has real good info on spring rates etc.
Posted: Tue May 20, 2008 05:37 PM
Sooo, here's an update on my progress: NOT MUCH. Laughing
I've got the front end mostly disassembled. Next step is to separate and remove the tie rods, then remove the spindles, and at that point the beam is pretty much ready to come off. I'm running into a couple minor issues like my caliper mounting brackets- the mounting holes for the bracket don't quite line up with the three holes in the spindle (where backing plate was mounted), so I'll have to see about getting the right ones for that. Also, some wheel bearing size issues with my spindles. I asked the seller I bought my SACO setup from if they could be used with stock VW spindles, to which he replied YES, no problem. Well, I've found a problem or two! Crying or Very sad I'm sure they're problems that can be easily resolved though, we'll just have to see how much it costs me to solve them!
We'll see how things go here...
Posted: Wed May 21, 2008 01:17 AM
Is the setup you have for BJ disks? Cause your running L/P now right?
Posted: Wed May 21, 2008 05:44 AM
No, I don't think so. Came off of a rail that was almost a pre-runner. I'm sure there was no way it coulda been a BJ beam- the thing was SICK.
Yes, my car is LP.
Posted: Wed May 21, 2008 05:51 AM
But if it came off a combo spindle then it would be a BJ setup, it is smaller then the one you have right?
Posted: Thu May 22, 2008 06:23 AM
I'm not gettin' what you're asking. The pattern for the three mounting screws on the caliper bracket is a larger pattern than on my stock linkpin spindle. They're close, but the pattern on the spindle is smaller.
Maybe what we've got going here is a misunderstanding of what the "combo" in combo spindle really means. Confused
18 Dirtjunkie 7550 Official 2016 Hassaymp...
 Tue Nov 08, 2016 03:49 AM
No new posts Projects and Builds Suspension Help 5 RDMINAZ 4787 Suspension Help
 Mon Jul 18, 2016 03:06 PM
42 wideopenmotorsports 15735 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 04:14 AM
1 LittleBaja 2430 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2276 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
