Visitors: 111
Total: 111
16: Pictures
22: Pictures
27: Pictures
29: Home
40: Pictures
43: Pictures
45: Pictures
59: Event Calendar
73: Pictures
74: Event Calendar
79: Pictures
80: Pictures
84: Drivers
100: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How did you construct your seat tilt mechanism?
planenutz
planenutz
Post Post subject: How did you construct your seat tilt mechanism?
Posted: Sat May 17, 2008 08:26 AM
Howdee all,
What ideas did y'all come up with for passenger access to the back seat of your Baja's? I've got 5-point belts so that complicates it a wee bit.
Looking for ideas to ponder while I sit here at work. Rolling Eyes
Thanks
Post Post subject: Re: How did you construct your seat tilt mechanism?
Posted: Sat May 17, 2008 09:09 AM
I do not have a back seat Smile
Posted: Sat May 17, 2008 02:42 PM
I did mine the hard way. Cool
www.chircoestore.com/c...ts_id=4935
planenutz
planenutz
Posted: Sat May 17, 2008 09:49 PM
Ya, I saw those. My seat bolts to the cage and I wasn't looking at cutting the cage to re-attatch it to the floor. Plus there's the prob of the 5-points coming out of the holes in the seats every time you tip it.
Interested to see what intersting engineering people came up with. Cool
Sample
Sample
Posted: Sat May 17, 2008 11:08 PM
planenutz
planenutz
Posted: Sun May 18, 2008 07:15 AM
Sample, how do you keep that cross-pin latch in place? Cotter pin?
Posted: Sun May 18, 2008 07:41 AM
Sample...
I'm REALLY liking that set up. It's clean, neat, simple, and well designed.
However, a lot of us are running high back seats. When the seat tilts forward, it soon hits the ceiling. This severely limits the amount of seat travel for us "High Backers" and makes it fairly impossible to get to the rear seat easily. I have mocked up a set-up for years and years that would be able to both tilt the seat, and slide it forward easily. It's a real pain in the ass, and I've never personally been able to get it to work successfully myself.
The problem is compounded by the fact that I run 5 point harnesses on the front seats. When the seats are tilted that far forward, the buckles on the harnesses will not clear the seat through the length of travel. I've tried to fasten the harness directly to the passenger's seat, and this certainly makes it an easier problem to solve, but there is a trade-off for the passenger's safety that I wasn't willing to sacrifice. I gave this quest up years ago, figuring I'd eventually get back to it if I needed to. Since then, my kids are both 6' tall and they don't fit in the back, so for me it's a mute point for now. I've got a 1 year old and one more in the oven now, so I may need to revisit this in a few years.
I'd love to see someone solve this.
The way I've run mine for years is I have two angle steel pieces bolted to the seats. I welded two 1"x2" steel tubing pieces to the seat bases. I have two long pins (1/2" diameter x approximately 12" long) that run through holes in the two abovementioned parts and pin it all together. When my kids were smaller, I'd just remove the seat when I dropped them off at school in the baja. I got some strange looks, but it worked OK.
planenutz
planenutz
Posted: Sun May 18, 2008 08:25 AM
57baja wrote:
.... a lot of us are running high back seats. When the seat tilts forward, it soon hits the ceiling.
It might work, if we put the hinge/pivot point farther back from the front edge.... Hmmm... (Pondering...)
If the pivot point is near the center of the base, near where the lap belts come through, they may not pull out of the seat. I think we're just screwed on the shoulder belt though. Mine wraps around a roll cage bar that goes behind the seats. Maybe a latch on the back side of the shoulder harness, behind the seat? Unsnap it when you fold the seat forward so the belt goes with the seat?
Posted: Sun May 18, 2008 07:06 PM
I used to actually wrap the shoulder harness around the two slats in the back of the seat itself, and fasten it that way. When you do that, the shoulder harnesses stay attached to the seat. My biggest concern was that in the event of a head-on collision, the seat would be the only thing holding the passenger taught. I worry about if it would hold a 200 lb person without tearing off the base.
nukeworker
nukeworker
Posted: Sun May 25, 2008 08:27 PM
I got some seats from the junkyard out of a two door ford escort. They're comfortable and the backs tilt forward for access to the back seat area.
Posted: Mon May 26, 2008 03:48 AM
DAMN!
57, you've got me wondering now. I liked "samples" set up so I took off with that. Some thing similar any way. Each car seems to present different needs I think so I adjusted to my needs. I got high backs so I'm wondering if they'll tilt w/o hitting. At leat all I'm concerned about is small children (relatives) and a big poodle as all our kids are grown up,,,,woo-hoo!
I'm not sporting 5-points,,,,,yet. I'm just a "wanna-be".... Very Happy
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 3633 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
No new posts VW Volkswagen & Baja Bug General Discussion will a superbeetle back seat fit into a 68 bug? 3 jasonrc2008 1615 will a superbeetle bac...
 Tue Aug 28, 2012 11:11 PM
No new posts Projects and Builds Brandwood Single seat project
New project side I just picked up
9 hanksgt 6298 Brandwood Single seat ...
 Thu Aug 02, 2012 07:43 AM
No new posts VW Volkswagen & Baja Bug General Discussion seat mounts 4 pussiwillow 3540 seat mounts
 Wed Feb 02, 2011 08:56 PM
pussiwillow View latest post
No new posts VW Volkswagen & Baja Bug General Discussion '65 Baja Back seat
info needed on finding and installing back seat for 65 baja
2 tkgeorge_99 1425 '65 Baja Back seat
 Sat Oct 02, 2010 06:36 AM
az350x View latest post
