Visitors: 129
Total: 129
15: Event Calendar
24: Home
27: Pictures
40: Event Calendar
46: Event Calendar
59: Event Calendar
72: Home
79: Home
99: Event Calendar
106: Event Calendar
123: Event Calendar
126: My Account
127: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Mounting one piece frontend
rummie
rummie
Post Post subject: Mounting one piece frontend
Posted: Sat May 17, 2008 07:21 AM
HELLO
Can anyone give me advice on other ways to mount a onepiece frontend and still utillize the tilt. I still have the gas tank up front and do not want to clamp to the front beam or use that old school front bumper. Has anyone used the two front bodymounts to do this ?. My bug has a bodylift so there is a little room there on top of the balljoint front beam.
pics and words welcome Idea
thanks
Post Post subject: Re: Mounting one piece frontend
Posted: Sat May 17, 2008 07:32 AM
Welcome aboard, by the way!!!
I didn't use the tilt when I did mine. I don't like the goofy aftermarket bumper, either. I made my own. I use two cotter pins to secure mine to pins on a plate welded to the front bumper from underneath, and Dzus fasteners on the sides. Most guys cut the fenderwells out of the car, too, but I kept mine, and they fit fit snug up against the inside of the 1pc. to keep the dirt and crap out of my gauges.
Maybe a picture or two will help you visualize it better...
[img]http://i292.photobucket.com/albums/mm35/57baja/baja21.jpg?t=1211002299[/img]
Make sense?
rummie
rummie
Posted: Sat May 17, 2008 07:46 AM
Makes sence
but now Iam drooling also makes sence
rummie
rummie
Posted: Sat May 17, 2008 07:48 AM
Makes sence
Posted: Sat May 17, 2008 08:12 AM
You could probably do something similar with a hinge on the plate instead of the pins if you wanted easy access to the gas tank. You could also cut a hole in the f/glass for access to the tank, too, if you didn't want to lift it to fill the tank. I'm sure someone here will post a picture of how they did that.
Posted: Sat May 17, 2008 09:10 AM
look at some photo's of my baja and you can see the hole in the hood I use to put gas into my baja.
Patzke
Patzke
Posted: Sun May 18, 2008 10:15 AM
57Baja:
CLEANCLEANCLEANCLEANCLEANCLEANCLEANCLEANCLEANCLEAN.
gahhhhhhhhhhh i love it. Smile
GREAT work!
Posted: Sun May 18, 2008 03:56 PM
Posted: Sun May 18, 2008 07:11 PM
I recognize that cap!!! It's a motorhome sewer access cap for the bottom of the dump compartment. I've got those at work. Clever use James!
Posted: Tue May 27, 2008 06:32 AM
57Baja, i just realized something, you have the EXACT same rear tires i do. same tread pattern and everything, I'M DOING SOMETHING RIGHT ! Shocked ! your's are 33's right? mine are 31's
k i'm done thread-jacking Very Happy
No new posts VW Volkswagen & Baja Bug General Discussion Looking for a one piece race hood 11 CrisC918 6871 Re: Looking for a one ...
 Tue Feb 03, 2015 08:45 PM
No new posts Projects and Builds One Piece hood 5 PaDan 4995 One Piece hood
 Wed Sep 28, 2011 04:12 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to get and where NOT to get one piece front end?? 6 Poomwah 3678 where to get and where...
 Mon Aug 01, 2011 03:32 AM
Poomwah View latest post
No new posts VW Volkswagen & Baja Bug General Discussion carbon fiber one piece front end 2 jt1957 3043 carbon fiber one piece...
 Mon Jul 11, 2011 09:52 PM
No new posts VW Volkswagen & Baja Bug General Discussion carbon fiber one piece front end 1 jt1957 2500 Re: carbon fiber one p...
 Mon Jul 11, 2011 06:11 PM
