Latest: BlackIrish05009
Overall: 3574
Visitors: 108
Total: 108
03: My Account
07: Event Calendar
63: Event Calendar
68: Home
81: Event Calendar
82: Event Calendar
99: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Stock speedo calibration?
Post Post subject: Stock speedo calibration?
Posted: Sun May 11, 2008 05:36 AM
Can you swap a gear in a stock speedo to calibrate it for oversize tires?
Just curious.
Post Post subject: Re: Stock speedo calibration?
Posted: Sun May 11, 2008 05:39 AM
I would imagine so. However, speedometer shops sell geared adapters that will fit between the back of your speedo and the cable. You can gear a ton of different gear ratios. If you do the math, you can figure the difference between your tire size and the original tire size and put the exact adapter in that you need.
In fact, you could probably find them online.
Posted: Sun May 11, 2008 06:59 AM
Look up Dick's Speedo & Tach.
1 suburbangorilla 3045 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 6578 Wheel travel stock vs....
 Tue Jan 31, 2012 02:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Does any one local to Chandler AZ stock 7x15 tires? 3 tobiism 8524 Does any one local to ...
 Wed Dec 14, 2011 02:46 AM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1778 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Does the stock speedometer have a light? 2 pschneider 2311 Re: Does the stock spe...
 Wed Jun 02, 2010 04:45 AM
nukeworker View latest post
