Latest: ecthemc
Overall: 3567
Visitors: 165
Total: 165
05: Event Calendar
13: Event Calendar
27: Event Calendar
55: Garage
72: Event Calendar
139: Event Calendar
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Stock speedo calibration?
Post Post subject: Stock speedo calibration?
Posted: Sun May 11, 2008 05:36 AM
Can you swap a gear in a stock speedo to calibrate it for oversize tires?
Just curious.
Post Post subject: Re: Stock speedo calibration?
Posted: Sun May 11, 2008 05:39 AM
I would imagine so. However, speedometer shops sell geared adapters that will fit between the back of your speedo and the cable. You can gear a ton of different gear ratios. If you do the math, you can figure the difference between your tire size and the original tire size and put the exact adapter in that you need.
In fact, you could probably find them online.
Posted: Sun May 11, 2008 06:59 AM
Look up Dick's Speedo & Tach.
1 suburbangorilla 2639 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 6118 Wheel travel stock vs....
 Tue Jan 31, 2012 01:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Does any one local to Chandler AZ stock 7x15 tires? 3 tobiism 8272 Does any one local to ...
 Wed Dec 14, 2011 01:46 AM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1613 rack & pinion w/stock ...
 Wed Nov 09, 2011 06:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Does the stock speedometer have a light? 2 pschneider 2179 Re: Does the stock spe...
 Wed Jun 02, 2010 04:45 AM
nukeworker View latest post
