Visitors: 141
Total: 141
10: Pictures
23: Pictures
24: Event Calendar
37: Event Calendar
39: Home
43: Home
76: Pictures
84: Home
111: Event Calendar
123: Event Calendar
124: Event Calendar
132: Home
135: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- mellrow spray coupe
mellrow spray coupe
4play
4play
Post Post subject: mellrow spray coupe
Posted: Sat May 10, 2008 02:02 AM
I do not know if eany of you know what a spray coupe is. but I found one in the junk yard to day. It has a vw moter and a 6 rib trany. it is a singal port moter the anly number i can find says type 126 industrel moter,the trany looks to be a 6 rib but the axels are splined.I took pitchers but my computer is sloooooooooow.
any in put, is it worth 50$
4play
4play
Post Post subject: Re: mellrow spray coupe
Posted: Sat May 10, 2008 02:46 AM
VIN70
VIN70
Posted: Sat May 10, 2008 03:15 AM
50 bucks cant really go wrong...escpecially with a 6 rib
Posted: Sat May 10, 2008 05:22 AM
/|\ /|\ /|\ What he said! /|\ /|\ /|\
Posted: Sat May 10, 2008 05:23 AM
buy it!!
Posted: Sat May 10, 2008 09:05 AM
You can get $500 for the trans alone. BUY IT!!!!!!!!
Posted: Tue May 13, 2008 08:35 AM
yes buy it.
4play
4play
Posted: Wed May 14, 2008 03:50 AM
Laughing I did,5 minits with a torch and 50$ It was in my truck. the moter turns by hand the shifter seems to go in to every gear so well see if it will start, maby thit weekend.
oldfart
oldfart
Posted: Wed May 14, 2008 05:25 PM
ok. I'll step forward and confess that I had to google it. I thought it was some sort of kit car I'd never heard of.
Never seen one on the 17 or 60.
Crash
Crash
Posted: Thu May 15, 2008 04:29 AM
What do you mean the axles are splined? Do they have a slip joint in them or is the outer end different?
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
4play
4play
Posted: Fri May 23, 2008 03:55 AM
the axels are a 2 peace and slide together
No new posts VW Volkswagen & Baja Bug General Discussion Spray on truck bed liner?
15 liftman_2002 17430 Re: Spray on truck bed...
 Sun Sep 21, 2008 01:44 AM
WaBaja View latest post
