Latest: jor_dang420
Overall: 3597
Visitors: 76
Total: 76
15: Event Calendar
18: Event Calendar
58: Event Calendar
61: Pictures
74: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Check your CV bolts...ask me why.
ditch68
ditch68
Post Post subject: Check your CV bolts...ask me why.
Posted: Thu May 01, 2008 02:07 AM
So I leave work at lunch for a 3 mile rip down the freeway for a run to the taco shop. I get back, roll in the gate, and just as I get to the last security bump I hear a clunk, and now the throttle does nothing. I figure it popped out of gear...but shifting does nothing. Clutch feels right, WTF?
Amazingly, I coast into my parking spot s l o w l y...and turn it off. I look at the shift linkage, I figure the coupler popped. Nope...the hockey stick must be engaging. Hmmm.
So I poke my head underneath just in case, and what do I see?
ALL 6 ALLEN BOLTS ON THE LEFT INNER CV JOINT WORKED LOOSE. Shocked The CV and axle were just resting on the frame horn with a bunch of grease, where it had been rotating as I slowly coasted through the parking lot.
HOLY CRAP. I had moments before been going 65 mph on the freeway. If that last thread on that last bolt had let go then, I would have had an axle and CV joint tied to the hub FLAILING my entire left trailing arm area, including brake likes, heads, exhaust, then flying down the freeway when it finally beat itself free, possibly through someone's windshield.
I didn't even lose or bend any of the bolts. I reassembled it and drove home this afternoon.
Man, I am one lucky dude. Period. What were the odds of that happening? I have been told I have freakish good luck by more than one person on more than one occasion. I am starting to believe it.
I'm lockwiring those some bidges.
Be warned...proper preventive maintenance is essential. The bear is,I was just under there looking around a couple days ago, and I do check them when I am down there...I am not kidding.
Whew. I'm a little freaked out.
Jeff
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
tody
tody
Post Post subject: Re: Check your CV bolts...ask me why.
Posted: Thu May 01, 2008 02:39 AM
wow that sucks. glad to hear you or anyone else was not hurt.
"A good plan violently executed now is better than a perfect plan executed next week."
"A pint of sweat, saves a gallon of blood."
-- George S. Patton
Posted: Thu May 01, 2008 05:30 AM
Glad to here the VW didnt get hurt.. Jk, worked out good Smile
ditch68
ditch68
Posted: Thu May 01, 2008 06:05 AM
The CVs and boots look new, maybe the previous owner just tightened them, but didn't hit the 25 ft pounds, or who knows?
Either way, I will be lockwiring all of them!
Jeff
Posted: Thu May 01, 2008 06:13 AM
Better now then later.
So what plans you got for your VW now?
Posted: Thu May 01, 2008 08:14 AM
Good insight for all ditch, glad you're OK. I had a similar experience once, but I won't jack your thread. It can be quite hair raising. Be very thankful. Someone must be looking after you!
Posted: Thu May 01, 2008 04:34 PM
Jeff
If you would start a thread on how you safety wired them, not easy to do for those who have never properly safety wired before. Also drilling holes in the bolts should be a hoot to. I got lazy and used regular lock washer and blue locktite. Ya dodged a bullet on this one.
Zoom153
Zoom153
Posted: Thu May 01, 2008 05:09 PM
The same thing happened to a D3 guy (hotsauce) on the way to BOR, real fun to fix on the side of I-10. Redneck ingenuity won out to get it there for further repairs. I'll be keeping a 12pt in my car for every drive.
65 Type 11
ditch68
ditch68
Posted: Fri May 02, 2008 01:37 AM
Share your story, '57. This thread isn't about me, it's about SAFETY!
Leather, I hear you on the bolt drilling. I will try to source some pre drilled bolts....maybe I'll get lucky. Otherwise, I will be buying several drill bits for the drill press. That will be a FUN job.
WaBaja....keep an eye on my build page. I will be doing tires next, then the great Warrior beam fiasco begins! +6 wider, +4 longer...
...and plus $1000 expensiver.
Jeff
Posted: Fri May 02, 2008 02:27 AM
Ha. Sweet. I just put new front tires, and wrangler seats (ill post some pics in my thread)
Can you PM Me a pic of how your side bars connect to the body/or cage.
piezzi
piezzi
Posted: Fri May 02, 2008 02:38 AM
You can get the pre-drilled bolts here:
www.bugsandbuggies.com...2&GN=4
Would love to learn how to properly seize the bolts if someone would like to share.
ditch68
ditch68
Posted: Fri May 02, 2008 03:08 AM
I will do a tutorial with photos when I do it. It's pretty simple - if you have a safety wire pliers. In fact, without one, it will be quite a pain. The concept is that you gang 2 bolts together so that the wire is pulling the 2 so that they can not move in the loosening direction.
Thanks for the lead on the bolts!!
Jeff
planenutz
planenutz
Posted: Fri May 02, 2008 08:21 AM
See here:
www.whizwheels.com/Tip...iring.html
Posted: Fri May 02, 2008 07:16 PM
you need the little specil lock washers that go with the bolts. Ask for them at chirco's etc. I hve had happen to me to and this was the fix. Next xtep was safty wire.
Posted: Sat May 03, 2008 01:15 AM
something esle to check for pre-flight.....thanks for the heads up jeff.
good thing it didn't let go on the freeway.... Shocked
No new posts New Members Transaxle Bolts stripped 7 LittleBaja 3588 Transaxle Bolts stripp...
 Tue Dec 01, 2015 05:38 PM
Broncoboy519 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What size are fender bolts? 2 az350x 2820 Re: What size are fend...
 Thu Dec 02, 2010 11:30 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion CHECK YOUR PIVOT BOLTS!!! 2 BugZyla.com 2940 CHECK YOUR PIVOT BOLTS...
 Thu Sep 09, 2010 10:38 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Marks nuts and bolts on westside-- 3 Brettucks 2584 Marks nuts and bolts o...
 Sat Jan 30, 2010 06:18 AM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion frame horn bolts 2 Colesifer68 1997 frame horn bolts
 Mon Jan 11, 2010 10:22 PM
Colesifer68 View latest post
