Visitors: 90
Total: 90
08: Event Calendar
63: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Anybody know a good/resonable welder?
mrscsi
mrscsi
Post Post subject: Anybody know a good/resonable welder?
Posted: Tue Apr 25, 2006 05:06 PM
Being new to the valley I need to know if anybody knows a good/reasonable welder. I had to pull my rear cage to replace the tri-mill with a quiet pack and will need to extend my cage about 15”. What I want to do is take the same size tubes both inner and outer and sleeve 4 extensions so I can slide those onto the mounts already on the car and bolt them and then just slide the cage onto the extensions and use pins to hold them.
I will be out of email contact for about 2 days while I move into town so I will check this when I get back on but thanks in advance for any suggestions.
Dave Brown
Post Post subject: Re: Anybody know a good/resonable welder?
Posted: Wed Apr 26, 2006 05:58 AM
dont know how much your looking to spend, but i bought mine at lowes. its a lincoln pro-core 100, its wire feed and will weld up to 1/4" material. i think i spent around 350 for it. what ever you do, resist buying a cheap chinese piece, from harbor freight, you'll be sorry... Evil or Very Mad
Say10
Say10
Posted: Wed Apr 26, 2006 06:14 AM
I could take a look at it for you....wouldnt be much to do what you want.
Posted: Wed Apr 26, 2006 06:30 AM
if your gonna buy a welder at least go mig with gas.
if you have experience, id use old fashioned arc but thats just me.
bajasam96
bajasam96
Posted: Wed Apr 26, 2006 07:23 AM
Watch the Pawn shops, they rarely know when they have real quality tools apart from the standard junk. I cant think of the brand of it right now, but I got quite a gem for $75 (new in box!)
mrscsi
mrscsi
Posted: Sun Apr 30, 2006 04:01 AM
Well I got back online today (4 friggin days of messin with the dish only to find I had a bad coax.) What I was needing was a "welder" not the actual welder Smile but thanks for all the responses anyway.
Say10 - I want to get with you, it wouldn be much of a project just need 4 15" tubes tacked or welded with 4- 6" tubes that will slide inside the 15" ones.
I guess I could just use bolts and bolt it together just seems a little easier to just weld em up and slip em on.
Dave Brown
Posted: Sun Apr 30, 2006 06:51 AM
if you are having tubes welded together, you need to make sure that the person doin it is qualified enough to do a proper seam (especially if you need strength from it)
check with chewbacca (bugzylla)
Posted: Sun Apr 30, 2006 07:16 AM
You building a rocket launcher or what?
mrscsi
mrscsi
Posted: Sun Apr 30, 2006 09:07 AM
Yeah so we can target your trailer queen and put it out of our misery Smile no just extending a rear cage after putting on a new exhaust.
Dave Brown
bajajon
bajajon
Posted: Sat May 06, 2006 07:43 AM
i bought a 110 mig gas welder at harbor freight for 150 bucks and it kicks ass suprisingly, thats the perfect first project for welding after a little practice on scrap, plus you can say you did it! look up a welding web site for some tips. if you know the right teqniqe from the beginning it speeds up the learning process alot.
dang, I broke it again
Posted: Sat May 06, 2006 09:30 AM
My trailer queen was allready put out of its misery. I just sent it to Vegas to be stored at my Dads house. Crying or Very sad (no space at the new house)
29 AzBaja 32542 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
8 AzBaja 3625 photobucket.com is a n...
 Fri Jul 07, 2017 11:37 PM
51 Yummi 29525 Doing good things for ...
 Sat Dec 14, 2013 10:00 AM
No new posts VW Volkswagen & Baja Bug General Discussion made a good score......... 1 vtbaja 1934 Re: made a good score....
 Wed Oct 09, 2013 12:19 AM
No new posts VW Volkswagen & Baja Bug General Discussion Doing good things for a Marine 2 Yummi 2657 Doing good things for ...
 Sun Sep 15, 2013 04:53 AM
