Visitors: 100
Total: 100
13: Event Calendar
15: Event Calendar
29: Event Calendar
63: Event Calendar
84: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Cargo area and heater ?tinnels? replacement.
Post Post subject: Cargo area and heater ?tinnels? replacement.
Posted: Tue Apr 15, 2008 05:47 AM
Should I just put a bent L piece of 1/8 metal to replace my cargo and firewall?
By my jack support, they made my heater ?tunnels? collapse and crack, and then rusted through. Ill get pics.
And inside by the front vent by my pedals, its rusted through..
I have a small spot on my battery area (passenger side) too but im going to replace the whole 1/4 pan from chirco.
Post Post subject: Re: Cargo area and heater ?tinnels? replacement.
Posted: Tue Apr 15, 2008 04:32 PM
IMO 1/8 inch sheet metal is way too thick. If it is rotted out bad, you can buy that whole piece. Mine is rotted at the firewall also, I am going to use an overlay since my car is caged and that is no longer a structural part.
Posted: Tue Apr 15, 2008 11:40 PM
Its not rotted, just cracked from the firewall mount engine guard.
I couldnt find the replacement piece
Posted: Wed Apr 16, 2008 05:00 PM
Here is the part: www.bfyobsoleteparts.c...p-118.html
Since the engine cage damaged it, you will need some re-inforcement so it doesn't happen again. Do you have a roll bar/cage? If not some thick metal like you were talking about is probably in order, in larger pieces to spread the load and sandwich the body panel. Make sense?
Posted: Wed Apr 16, 2008 11:30 PM
Thanks
I think ill pass though 8O... Ill just put some newer steel (pressed steel?) over like I seen on samba.
Id rather buy a warrior beam for 200 then a cargo replacemnt..
No new posts Events and Get Togethers World Wide Hassayampa at I-10 Closed! (Old Playday area) 2 Dirtjunkie 555 Hassayampa at I-10 Cl...
 Fri Oct 27, 2017 02:13 PM
No new posts Events and Get Togethers World Wide box canyon area this weekend.... 0 ikill6453 710 box canyon area this w...
 Thu Apr 13, 2017 03:49 AM
ikill6453 View latest post
No new posts New Members New member from Houston area
Lurking, learning, and searching
0 Mazda_wes 894 New member from Housto...
 Tue Feb 28, 2017 06:36 AM
Mazda_wes View latest post
No new posts VW Volkswagen & Baja Bug General Discussion fan belt replacement 0 azdesertrat87 1567 fan belt replacement
 Sat May 23, 2015 04:58 AM
No new posts VW Volkswagen & Baja Bug General Discussion new here. Any street guys from Mesa area? 2 ExtremeBean 2489 new here. Any street g...
 Fri Apr 10, 2015 12:36 AM
JWHracing View latest post
