Latest: hulkbaja
Overall: 3594
Visitors: 114
Total: 114
45: Event Calendar
48: Event Calendar
54: Links
59: Garage
61: Event Calendar
95: Drivers
103: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Can the adjusters be rotated?
zx10r203
zx10r203
Post Post subject: Can the adjusters be rotated?
Posted: Sat Apr 12, 2008 04:20 PM
If I was to rotate the adjuster 1/4in up (the same as just cut and turning a stock beam) would that still raise the front without changing the spring rate if the adjuster was on its lowest setting??
and if I want a stiffer spring rate than I could crank the adjuster?!?! Is this correct??
Post Post subject: Re: Can the adjusters be rotated?
Posted: Sat Apr 12, 2008 06:13 PM
You'll lose your adjustability
zx10r203
zx10r203
Posted: Sat Apr 12, 2008 06:18 PM
But by turning the adjuster screw as if you were raising the front would that make it for a stiffer ride??
Posted: Sat Apr 12, 2008 06:43 PM
Depends on if you have removed your stops, but the farther away from stock you go the rougher the ride can be, also remember in most cases they are 30+ year old springs, possibility of breaking is there too.
zx10r203
zx10r203
Posted: Sat Apr 12, 2008 08:24 PM
I thought about the old leaf springs being too old so I was going to replace them anyways. The way I understand is that if I was to rotate the adjuster as if I was cutting and turning the stock nut and bolt assembly I would still get the height and stock ride if the adjuster was set to the lowest setting. If I wanted it to stiffen the ride I could just turn the bolt on the adjuster.
Am I right on this or way off?!?
Posted: Sat Apr 12, 2008 11:57 PM
You're right, but why wouold you want to make the ride even stiffer??
zx10r203
zx10r203
Posted: Sun Apr 13, 2008 12:06 AM
I am not saying i would want to. I just want to make sure that I am understanding the concept.
Does the adjusters provide the same height as cutting and turning? If they don't I can turn them 1/4" in to get maximum height
Posted: Sun Apr 13, 2008 01:12 AM
I am going to run lift spindles. You should too. Im assuming 3" is going to be hard to get out of a ball joint (vw) any other way, besides body, but that just helps you run bigger tires (and bigger tires only give you a tiny bit of clearance... 30s and 33s are only 1.5" ground clearance different, yet alot more strain on your motor.
Posted: Sun Apr 13, 2008 01:20 AM
It will provide the ability to raise as a cut and turn and also lower the front end too.
zx10r203
zx10r203
Posted: Sun Apr 13, 2008 04:46 AM
Whats the maximum height the adjusters raise the front??
DeMilled
DeMilled
Posted: Sun Apr 13, 2008 01:17 PM
I am not sure exactly how much the adjusters will raise your car but I went out and measured the amount of adjustment I have on my adjusters. My adjuster are for a ball joint beam from mooreparts.
I measured a grand total of 5/8th" adjustment at the adjuster.
I set my adjusters all the way at the bottom of their adjustment and then welded them in the beam at the angle of a minor cut and turn....the grub screw was at approximately 4 O"CLOCK (look at where yours are sitting stock and add a bit of a cut and turn to them). From here I can crank another 5/8th" adjustment and I think that will be plenty for me.
FYI I am going to run 181 spindles/arms so I have about 3" of lift right there. I will crank the adjusters to stillen the suspension when I need it for running hard off road.
DeMilled
DeMilled
Posted: Sun Apr 13, 2008 01:34 PM
If you crank the torsion bars in the beam by any means, be it a cut and turn of the stock set up, or by turning the adjusters you are going to do two things....
1 Raise the ride height of the car.
2 Make the ride rough/stiff.
You cannot use the torsion bars to raise the ride height without a stiffer ride/spring rate.
If you want to keep the stock spring rate and get lift you need lift spindles.
The best of both worlds is a set of lift spindles combined with adjusters so you can tune the spring rate for rough running.
Posted: Sun Apr 13, 2008 04:14 PM
The height on this was a on the ground 16"
zx10r203, you have a pm
No new posts VW Volkswagen & Baja Bug General Discussion Broken Valve Adjusters 3 zfriek42083 2205 Re: Broken Valve Adjus...
 Sun May 20, 2007 11:51 PM
zfriek42083 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion torsion adjusters? 7 speedtrash 4736 Re: torsion adjusters?
 Sun Jul 30, 2006 04:56 PM
