AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- TDC, 90* out? wth
TDC, 90* out? wth
Users browsing this topic:
None
Author |
Message |
Post subject: TDC, 90* out? wth
Posted: Fri Apr 11, 2008 11:42 PM
Ok im top dead center, no questions asked. I know that much.
My rotor is pointing 90* to the right, Instead of pointing back left (top view) its pointing back right (top view).
Pulley says TDC, #1 cylinder is up top most.
_________________ 66 baja in the works!
+3
Post subject: Re: TDC, 90* out? wth
Posted: Sat Apr 12, 2008 12:36 AM
I redid it, i guess 009s are 90* different than the other stock distr. So I set timing, and firing order is correct, I tried both options, since im 180 out.
So... Timing, firing order, gas, spark, oxygen.
Spark plugs, i regapped nad cleaned, once I Get money ill buy new ones, if it still doesnt run im going to be bumedd!
+34
Posted: Sat Apr 12, 2008 05:43 AM
That is correct. The rotor will point to the passenger's side rear on a 009 when #1 is at TDC. Coincidentally, there is a small notch in the metal housing (lip) on the distributor under the cap that will line up with the rotor when #1 is firing.
Whattaya mean you're 180 degrees out?
Posted: Sat Apr 12, 2008 06:15 AM
I heard its suppose to point 90 more clockwise, which mine is 90 more counter clockwise (passenger rear) but all is good now.
I am going to redo valve adjustments tomorrow. And tinker with it, then when i get my 200 bucks ill go get some junkyard heads, strip them down and have my friend sand blast them, and then put new parts on them. Then ill put new rings on and look at my jugs etc.
+34
Posted: Sat Apr 12, 2008 06:32 AM
You should be able to pick up heads much cheaper than that!
Heck, you've probably got guys here with heads sitting around. I may even have some. What size engine are you running? I'm assuming a stocker? Save your cash for '87's. Work your heads with a Dremel per the Fisher Book diagrams. Toss a set of 1.4's on it, and go! You could probably buy a rebuilt set of heads, maybe even new ones for less than you're talking about spending for junk. If you port them correctly, you can pick up a lot of ponies for a few hours of free massaging.
Posted: Sat Apr 12, 2008 06:36 AM
Delete this threadddddddddd
Posted: Sat Apr 12, 2008 07:04 AM
Delete!
+34
Posted: Sat Apr 12, 2008 08:25 AM
Ya gotta really start with a DP head to get any serious results. Remember that an engine is nothing more than an air compressor. It is equally important to get air in as it is to get air out as efficiently as possible. Find some DP heads and get to work!
Get the book if you don't have it already. It's worth every penny!
Posted: Sat Apr 12, 2008 08:44 AM
I heard single ports have beter low end torque.
+34
Posted: Sat Apr 12, 2008 10:07 AM
So would a 1/2" exhaust system, but I wouldn't run that either.
Posted: Sat Apr 12, 2008 09:32 PM
Well good news is... I found out whats wrong I think
Well bad news is worse... they range from 50-60 psi each cylinder. Should be over 100 Ive heard. (105) or so!
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
