Latest: hulkbaja
Overall: 3594
Visitors: 58
Total: 58
06: Pictures
07: Event Calendar
16: My Account
39: Event Calendar
42: Event Calendar
47: Event Calendar
51: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Shock for a b/j front??
Post Post subject: Re: Shock for a b/j front??
Posted: Thu Apr 10, 2008 05:55 PM
These are the next best thing to the FOX's: www.chircoestore.com/c...ts_id=4093
Then the KYB bus shocks mentioned above.
Both of these are for cut and turned front ends.
I don't think having the same shock frt and rear is of any benefit. Most of the mid travel cars run 8-10 in frt and 12-16 in the rear. Nothing is interchangable frt and rear.
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 05:57 PM
Would it be bad to run the Bilstein ^^^^ on a stock front (not cut and tuned)???
Basically what I am looking for is a good road ride since the car will be street legal and also good off road performance.
A friend of mine who has a street legal sand rail actually swaps shocks when he goes off roading (uses short king shocks). Then in the summer when he wants to drive the car on road he has to put in his road shocks (Tokico Illumina 5-way Adjustables).
Posted: Thu Apr 10, 2008 06:27 PM
They have a cheaper alternative, that shock is a entry level race quality.
Bilstein part # may be: B46-0620-H0 shows 5.49" travel as opposed to 6.65" travel with lighter valving.
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 06:31 PM
Is that a chirco part number??
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 06:32 PM
[quote="zx10r203"]
Is that a chirco part number?? And would the 1.16" of travel make that much of a difference?
Posted: Thu Apr 10, 2008 07:37 PM
Chirco's didn't show it on their site, but they may have it. Just tell Don the application. I found it on another site. Here is Bilstein's application guide:
www.bilstein.com/OffRoad.pdf
The difference in travel is from the application: cut and turn the beam and run a longer shock gets you more ground clearance, sits higher, and more travel since the shock is longer (more room before it bottoms out)
Is it worth it? Depends on what you want. I personally don't like the look of a stock height Baja, so to me it was worth the money I have thrown at mine.
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 08:28 PM
I am not too sure if I can cut and turn the beam myself. Is there a how to laying around somewhere with pictures for reference??
ChazLawler
ChazLawler
Posted: Fri Apr 11, 2008 04:47 AM
You could swap out your Type 1 arms and spindles and use Thing parts, instead. You would gain 3" in height plus not have to worry about the ball joint popping out of the lower arm. I also understand that Radflo (radflo.com) makes Class 11 shocks. I couldn't find any specs on their site, but read a thread on racedezert that mentioned these shocks.
zx10r203
zx10r203
Posted: Fri Apr 11, 2008 05:11 PM
Anymore info on the swapping the for the THING arms and spindles? Which to use and where to find it?
Posted: Fri Apr 11, 2008 05:31 PM
Watch the classifieds, Samba, craigslist, junkyards etc. Some times hard to come by and not real cheap. If you want to keep a nice ride and get more lift, but no more travel; www.blindchickenracing.com makes lift spindles for ball joint front ends. Mark, aka crash comes around this site on occasion.
Posted: Fri Apr 11, 2008 08:18 PM
www.blindchickenracing..._parts.htm
Scroll down to last product. 225+ shipping. 3" lift spindles..
Thats what ill be doing. Maybe. I dont know how to lift a swing axle without stupid camber problems!
zx10r203
zx10r203
Posted: Fri Apr 11, 2008 09:33 PM
If I install the adjusters will that affect the ride quality??
Meaning by raising the front will make it stiffer and lowering make it softer?!?!?
twistedsmily
twistedsmily
Posted: Fri Apr 11, 2008 09:41 PM
from what i understand asdjusters dont change the spring rate just the angle of the arms (but i could be wrong)
zx10r203
zx10r203
Posted: Fri Apr 11, 2008 11:16 PM
Thats what I thought until I read this on Chirco : "These adjusters allow you to adjust the height of your car, as well as dialing in the ride. You can make it stiffer or softer with the turn of a wrench."
twistedsmily
twistedsmily
Posted: Sat Apr 12, 2008 02:57 AM
ah well then ok didnt know they changed the spring rate of the packs guess we learn a little everyday hehe
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2329 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7675 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3517 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Hoops
Wanting to build shock mounts without cutting the body
29 POCman 24814 Re: Shock Hoops
 Thu Nov 15, 2012 08:50 AM
POCman View latest post
15 onthefarm 11279 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
