Latest: jor_dang420
Overall: 3597
Visitors: 78
Total: 78
23: Event Calendar
30: My Account
42: Pictures
46: Pictures
71: Event Calendar
73: Pictures
75: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Some questions
Some questions
fatalifeaten
fatalifeaten
Post Post subject: Re: Some questions
Posted: Wed Apr 09, 2008 07:28 AM
Points?
--Harlan Ellison
Posted: Wed Apr 09, 2008 07:38 AM
Thats what im going to buy first.
My fuel line is plugged.. Should I use aluminum fuel line? Steel?
Posted: Wed Apr 09, 2008 02:08 PM
The wiring schematic is the same if its 6v or 12v, you just have to change the bulbs, the generator and reculator & the wiper motor. The wiring doesnt change, just the voltage.
Posted: Wed Apr 09, 2008 02:10 PM
Plugged fuel line, take an old throttle cable and put one end in a drill and run it through the steel line just like a roto rooter. Use carb spray with it and it will help. After you get it cleared out spray more carb cleaner in the line and blow it out with compressed air.
Posted: Wed Apr 09, 2008 04:21 PM
Once it is unplugged find where the garbage is coming from, most times the tank either treat it or replace it, add another filter too.
Posted: Wed Apr 09, 2008 07:34 PM
Its the tank, my dad is cleaning it out today. And thanks bugzyla.
oldfart
oldfart
Posted: Thu Apr 10, 2008 03:39 PM
don't forget the little screen in the tank tap. I think even late 60-early 70's still had 'em.
Posted: Thu Apr 10, 2008 07:28 PM
Wait. I put the tank back in! Do I have to take it back out.?
Posted: Thu Apr 10, 2008 07:40 PM
Unless you can reach it through the filler or sending unit holes with it mounted. Also if you do pull it out, there is a good product from POR 15 to put in the tank and prevent more corrosion, fill tiny pin holes etc. You can get it from an auto paint supply store.
Posted: Thu Apr 10, 2008 08:55 PM
Its only 4 bolts, Ill just pull it out later.
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 5238 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 6000 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 2583 Tow Bar questions
 Mon Nov 16, 2015 02:45 PM
No new posts New Members New Guy Questions 6 Apoc 4375 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 8643 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
