Visitors: 303
Total: 303
19: My Account
20: My Account
24: Event Calendar
30: Home
35: Pictures
45: My Account
46: Event Calendar
48: My Account
49: My Account
51: My Account
52: My Account
54: My Account
55: My Account
56: My Account
57: My Account
58: My Account
60: My Account
61: My Account
73: My Account
104: Pictures
108: Pictures
121: My Account
138: Pictures
150: Baja Forums
163: Pictures
166: Baja Forums
169: Pictures
172: Pictures
173: Baja Forums
176: Baja Forums
177: Baja Forums
178: Baja Forums
179: Baja Forums
180: Baja Forums
181: Baja Forums
182: Baja Forums
183: My Account
184: Baja Forums
185: Baja Forums
186: Baja Forums
187: Baja Forums
189: Baja Forums
190: AMAZON.com
191: Baja Forums
192: Baja Forums
194: Baja Forums
196: Baja Forums
197: AMAZON.com
198: Baja Forums
202: AMAZON.com
204: Baja Forums
205: Baja Forums
206: Baja Forums
207: Baja Forums
208: Baja Forums
209: AMAZON.com
210: Baja Forums
211: Baja Forums
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: Baja Forums
221: Baja Forums
225: Baja Forums
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: Baja Forums
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: Baja Forums
237: Baja Forums
238: Baja Forums
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: Baja Forums
245: AMAZON.com
246: AMAZON.com
247: AMAZON.com
248: Baja Forums
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: Baja Forums
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: Baja Forums
259: Baja Forums
260: AMAZON.com
261: Baja Forums
262: Baja Forums
263: Home
264: AMAZON.com
265: Baja Forums
266: Baja Forums
267: Baja Forums
268: AMAZON.com
269: Baja Forums
270: Baja Forums
271: Baja Forums
272: Baja Forums
273: Baja Forums
274: Baja Forums
275: Baja Forums
276: Baja Forums
277: AMAZON.com
278: AMAZON.com
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: AMAZON.com
283: AMAZON.com
284: AMAZON.com
285: Baja Forums
286: AMAZON.com
287: Baja Forums
288: AMAZON.com
289: Baja Forums
290: Baja Forums
291: AMAZON.com
292: AMAZON.com
293: AMAZON.com
294: AMAZON.com
295: AMAZON.com
296: Baja Forums
297: AMAZON.com
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What Clutch and Pressure plate?
Post Post subject: What Clutch and Pressure plate?
Posted: Thu Apr 10, 2008 05:20 AM
What Clutch and Pressure plate do you recomend for both street and off road?
1973
1915 / Weber 48 IDF
IRS
Type 1 trans - reworked
Post Post subject: Re: What Clutch and Pressure plate?
Posted: Thu Apr 10, 2008 07:04 AM
Kennedy Engineering 1700 lb. pressure plate without a doubt. Clutch discs are a whole different topic. It's like asking someone what kind of beer they like. I'm using a heavy duty clutch plate that's spring loaded for smooooothness, but many prefer feramic three pucks or four pucks that are a bit more grabby. You should get a lot of varied answers on this topic, but we'll probably all agree on the Kennedy.
Posted: Thu Apr 10, 2008 05:41 PM
I agree w/57baja on the pressure plate, and a stock style disc. AZBaja pointed out in a post a long time ago, a clutch disc can be like a fuse, burn the clutch is much better than breaking the trans. The puck style are very harsh, there is no slippage, like a switch, engaged-not engaged. (hard on the trans, especially with your larger engine. Of course if you are in western Michigan and going to Silver Lake sand dunes, you can give your trans the test and run a puck style and paddles.
ridinthedunes
ridinthedunes
Posted: Thu Apr 10, 2008 11:08 PM
I ended up with, what I think is, a happy meduim, I went with a deiken (sp?), seems to grab well and still gives a little play in the peddle.
I'm running a little larger engine and the stock disk went away pretty quick and I just didn't like the "on/off" of the 4 puck.
I'm a fan of a little "slip" in the clutch though, saves on parts.
Posted: Thu Apr 10, 2008 11:54 PM
The Clutch is the fuse that saves your transaxle. I run a light plate with a spring disc. it's much cheaper to replace a burnt clutch than a broken transaxle. We had the car on the dyno last year and at 88hp the clutch would start to slip, so I might go up 1 step next time I have the engine out of the car...I'm not sure if I have an 1800lb or a 2200lb in it know. But for now it works great.
ridinthedunes
ridinthedunes
Posted: Fri Apr 11, 2008 01:03 AM
Yes, mine slipped pretty bad with a stock disk also. The dieken seems to be holding up pretty well though I dyno'd mine this year at 140/150 and it's holding up to that and still seems to have a "little give".
No new posts VW Volkswagen & Baja Bug General Discussion can we clarify the ohv/mc/regular plate/park pass stuff? 7 Brettucks 20198 Re: can we clarify the...
 Wed Feb 16, 2011 03:11 AM
Rickman View latest post
2180 Baja bug with 091 trans.
11 51BUG50 4267 Clutch and pressure pl...
 Fri Mar 10, 2017 07:22 PM
parts
0 bajablastman1214 2178 Clutch
 Sun Aug 16, 2015 05:23 AM
Really bad issues
4 Pointvirus 2555 Clutch Issues
 Mon Dec 03, 2012 06:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 6137 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
