Visitors: 164
Total: 164
15: Event Calendar
39: Event Calendar
40: Event Calendar
93: Home
94: Home
95: Home
103: Event Calendar
123: Event Calendar
124: Event Calendar
125: Event Calendar
126: Event Calendar
127: Event Calendar
131: My Account
150: Baja Forums
162: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Shock for a b/j front??
zx10r203
zx10r203
Post Post subject: Shock for a b/j front??
Posted: Wed Apr 09, 2008 10:08 PM
I noticed there are not that many shocks for the ball joint front.
What are my opitions?
Post Post subject: Re: Shock for a b/j front??
Posted: Wed Apr 09, 2008 10:30 PM
Same boat. I got an idea though. Jeep cherokees have that SAME stupid upper shock mounts. Well this company something that makes it run normal shocks.
store.jksmfg.com/merch...Code=Shock
LMK If this is what you mean. I thought about this myself.
zx10r203
zx10r203
Posted: Wed Apr 09, 2008 10:38 PM
The only problem I am seeing with that is that you lose a couple of inches of shock. May limit the travel!! But still thats a great idea!!
zx10r203
zx10r203
Posted: Wed Apr 09, 2008 10:40 PM
Posted: Wed Apr 09, 2008 10:46 PM
also in the same boat
wtracing
wtracing
Posted: Wed Apr 09, 2008 10:58 PM
i run KYB's i used to run empi coil overs and that was a big mistake
Posted: Thu Apr 10, 2008 03:02 AM
Only loose about 3/4 to 1" which isnt that big of a deal!
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 04:24 AM
Is that how big they are!! I thought it would be been a little bigger. I guess 1" isn't much when you get to install a better shock!!
nukeworker
nukeworker
Posted: Thu Apr 10, 2008 05:26 AM
Bilsteins. They got em for regular or cut and turned.
Posted: Thu Apr 10, 2008 05:41 AM
It says you loose 1.1" zx10.
It would be nice to run all the same shocks also, not stud shocks up front and different out back!
Posted: Thu Apr 10, 2008 05:48 AM
KYB,S GR-2
Posted: Thu Apr 10, 2008 07:08 AM
I used to use KYB GR-2's and they were great.
By looking at that picture, it looks like a Mickey Mouse solution. The stud looks too big for the top. I guess you'd drill the hole out bigger in your shock tower to make it work, but why shorten your travel? You want MORE travel than stock, not LESS.
.... Just my opinion...
ChazLawler
ChazLawler
Posted: Thu Apr 10, 2008 07:30 AM
Fox makes Class 11 reservoir shocks with 6.5" of travel. They are rather expensive, though, about $180 ea.
Posted: Thu Apr 10, 2008 07:41 AM
This is what route im going now
B/J
www.chircoestore.com/c...ts_id=1095
S/A
www.chircoestore.com/c...ts_id=1153
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 05:54 PM
Those are nice,but for $180 ($360 front only) a pop I can get more stuff for the Baja.
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2162 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7243 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3340 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Hoops
Wanting to build shock mounts without cutting the body
29 POCman 24017 Re: Shock Hoops
 Thu Nov 15, 2012 07:50 AM
POCman View latest post
15 onthefarm 10869 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
