Visitors: 93
Total: 93
44: Home
53: Home
90: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wiring Help
Wiring Help
72BajaBen
72BajaBen
Post Post subject: Wiring Help
Posted: Mon Jul 31, 2006 06:59 AM
I was making some dash inserts for my Baja. And i pulled out my headlight switch and my hazards and no other wires that i know of, and now nothing works. i wanted to rewire the baja anyway just to get rid of the rats nest that is in there. does any one know of a website that has some easy to read instructions. i want to have a push button ignition and im going to put my blinkers and head lights on toggle switches and the wipers. so if any one can help me out that would be awesome.
Thanks
Post Post subject: Re: Wiring Help
Posted: Mon Jul 31, 2006 08:18 AM
go here: 66.34.72.138/index.html
scroll down till ya find beetles, then select your year. click on green dot.
good luck!
Say10
Say10
Posted: Tue Aug 01, 2006 01:59 AM
Thats pretty damn handy.
elryano
elryano
Posted: Tue Aug 01, 2006 02:46 AM
you can use one of those buggy wiring kits. they are easy to install and work great in a baja
Say10
Say10
Posted: Tue Aug 01, 2006 03:24 AM
always wondered about that, seeings how they have just what is necessary.
72BajaBen
72BajaBen
Posted: Tue Aug 01, 2006 03:29 AM
yea im in the middle of rewiring it now. im stuck on the brake lights. i get the running lights to turn on but when i hit the brake pedal it does nothing. so when i figure that out and the blinkers then in gloden.
Posted: Tue Aug 01, 2006 03:44 AM
is the circuit connected to your massa cylinder?
72BajaBen
72BajaBen
Posted: Tue Aug 01, 2006 05:03 AM
yea it is...and im still not getting any brake lights
Posted: Tue Aug 01, 2006 06:35 AM
have you checked the old fuses under the hood? they pop out easily. my front parkin lights are out and i checked my fuse tonight, its missing.
VIN70
VIN70
Posted: Tue Aug 01, 2006 08:01 PM
do you have power at the switch? how about a good ground?
i did the same thing got toggle switches for everthing. makes your dash look clean. i used 2 flashers one for each side. easier that way, and you can have a dash light for each side.
72BajaBen
72BajaBen
Posted: Tue Aug 01, 2006 08:06 PM
does anyone know the config for the switch? if your looking at the switch is the top constant power and right is... and left is... i cant find this info anywhere.
VIN70
VIN70
Posted: Tue Aug 01, 2006 08:13 PM
i brlieve the right is to your lights left is power and top would be ground
72BajaBen
72BajaBen
Posted: Tue Aug 01, 2006 08:27 PM
awesome i will give it a try
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5542 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
Efi to carb
4 bugzapper 2757 Wiring
 Tue Jun 28, 2016 03:16 PM
28 seanoflinn1 11231 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Think I might have a wiring problem? 5 Roadrunner 2789 Re: Think I might have...
 Sun Aug 03, 2008 10:35 PM
sandshark View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VDO Guage Wiring Diagrams 1 BugZyla.com 2767 Re: VDO Guage Wiring D...
 Sat Feb 16, 2008 10:21 PM
jamesr6168 View latest post
