Latest: bawward
Overall: 3614
Visitors: 137
Total: 137
28: Event Calendar
32: Event Calendar
49: My Account
60: Event Calendar
68: Home
77: Event Calendar
91: Event Calendar
125: Event Calendar
130: Pictures
137: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Some questions
Some questions
Post Post subject: Some questions
Posted: Tue Apr 08, 2008 09:48 PM
Not sure what I got going on here
Might buy a rewire kit If I need to.
Clean (painted exhaust and unsiezed.
Side shot. Tree bar mounts will reinforce where the jack support bent upwards
fatalifeaten
fatalifeaten
Post Post subject: Re: Some questions
Posted: Tue Apr 08, 2008 10:00 PM
Ok, maybe I'm missing it, but what are your questions?
--Harlan Ellison
Posted: Tue Apr 08, 2008 10:34 PM
Ooops. I put the pics but no questions Sad
Does my wiring look normal or screwed with?
Those stock hood springs are STIFF.. VERY stiff. Take them off and make a hold-up bar?
Is it normal for the jack support to do what mine did. (last pic) I think Ill bend it back down carefully, and put some metal strips on each side and make my side bars off them.
fatalifeaten
fatalifeaten
Posted: Tue Apr 08, 2008 11:07 PM
Heh, your wiring looks "normally screwed with." 99% of all dubs on the road fit in this category. Is something specific not working?
Hood springs are designed to carry the full weight of a sheet metal hood, not a 'glass baja nose, so they're going to behave more stiffly on a baja. You might look at a set of gas struts from your local auto parts store. Usually the kind that are used on camper shells work well and come in lots of different sizes.
And lastly, yes. Especially with the rot in the panel right above it like that. They're not super strong to begin with and they weaken over time unless reinforced or replaced. You're never gong to use a stock jack on it since it's a baja, just sawzall it off Smile You're going to want to do something about those rocker panels too. How do the heater channels look?
--Harlan Ellison
Sample
Sample
Posted: Tue Apr 08, 2008 11:33 PM
It is very easy to wire a bug if you decide to re-do it.
I wish I had "hood" supports of some kind, instead of the piece of wood I use.
1966 Baja.
Posted: Tue Apr 08, 2008 11:58 PM
I can solder pretty good. So I know I can rewire, just gotta find me a schematics, or diagram (I have a huge chilton vdub manual)
I thought about going to the junkyard and find some struts. Even if they arent new they only have to hold a fiberglass hood not a whole metal hatch. I might go check on my XJ struts, and if they work. Junkyard time.
Heater channels look good, I Just rippd out cargo carpet, going to strengthen my cargo area, and put a gas tank later on with a filler neck to my rear window.
oldfart
oldfart
Posted: Wed Apr 09, 2008 12:16 AM
bugzyla posted a schematic in the last 2 weeks here, think it was bajachik or something. Heck your underhood wiring ain't bad at all. Someday that 'glass hood will span in two when you try to close it with those springs. Take 'em off and steal the wifes mop handle.
Posted: Wed Apr 09, 2008 01:49 AM
Wife.. You think im old or something :P! just playing Im only 16. but Its been converted to 12v. I just cranked it over, but no spark to my spark plugs so well see
Posted: Wed Apr 09, 2008 02:58 AM
Here is the simplest wiring diagram to follow. Its for a 65-66 bug.
P.S. Check the wiring from the generator to the voltage regulator. It looks a little backwards unless thats some off the wall aftermarket regulator.
Wiring
DF on on Reg to DF on Gen
D+ on Reg to d+ on Gen
B+ on Reg to Battery +
61 Terminal on Reg to Idiot Light.
Posted: Wed Apr 09, 2008 03:49 AM
Its a 12v conversion (not a 66 schematics since 66s are 6v)
Sample
Sample
Posted: Wed Apr 09, 2008 04:47 AM
Check for 12v going into the coil.
Posted: Wed Apr 09, 2008 05:20 AM
I did that. My dad says we arent getting coil to the spark plugs!
Sample
Sample
Posted: Wed Apr 09, 2008 05:38 AM
What kind of voltage from the - side of the coil to ground?
Posted: Wed Apr 09, 2008 05:53 AM
Im not sure. Do i need someone cranking while i check?
Sample
Sample
Posted: Wed Apr 09, 2008 05:54 AM
Check without cranking and with cranking.
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 6654 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 7572 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 3389 Tow Bar questions
 Mon Nov 16, 2015 02:45 PM
No new posts New Members New Guy Questions 6 Apoc 5169 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 10044 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
