Latest: Smokey4
Overall: 3593
Visitors: 110
Total: 110
52: Event Calendar
53: Event Calendar
72: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- replaced trans mount, now it wont start.
shpuz
shpuz
Post Post subject: replaced trans mount, now it wont start.
Posted: Sun Apr 06, 2008 01:28 AM
hey guys, i just replaced my transmission mount and now my baja wont start. i have power going into the dist., but no sparking. any idea's?
Quote::
Post Post subject: Re: replaced trans mount, now it wont start.
Posted: Sun Apr 06, 2008 02:18 AM
look for proper groundng.
tigerextra
tigerextra
Posted: Sun Apr 06, 2008 03:21 AM
make sure you put the tranny back in.
Laughing
like azbaja said, that grounding strap on the mount is probably left disconnected and lonely.. thats a good place to start. (after you make sure the tranny is still there)
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
Posted: Sun Apr 06, 2008 03:35 AM
Look down the carb, pump the gas, see a good stream of gas, what did you disconnect? Check points are still good,dizzy and rotor are good,all wires hooked up to the correct point, go back over everything, take your time, something simple.
shpuz
shpuz
Posted: Sun Apr 06, 2008 05:04 AM
well, my dad is telling me that when he hooked everything back up to the coil, he may have gotten some wires switched around and may have fried the coil. would that fry the coil or am i still looking for a grounding problem?
tigerextra
tigerextra
Posted: Sun Apr 06, 2008 05:12 AM
both. it really depends on what wires he hooked wrong.. specifically what he hooked where Very Happy
all 6 of us agree!!
tigerextra
tigerextra
Posted: Sun Apr 06, 2008 05:14 AM
grab your book and just quick look over what wires go where on the coil, dissy etc. DISCONNECT battery before you do anything else Laughing ... it is probably something really simple as stated above, just go over everything you touched since it last ran, and you WILL find the problem.
all 6 of us agree!!
shpuz
shpuz
Posted: Sun Apr 06, 2008 05:28 AM
first of all, i dont have a book Smile i know where they all go, i looked at it before we disconnected, but i didnt check it after he hoocked them up and i started it. so it could be a fried coil? ill check all the grounds tomarrow, but as far as i know none were disconnected.
tigerextra
tigerextra
Posted: Sun Apr 06, 2008 05:33 AM
yeeeeaaaaah....... check to see if they are now where they were before. if not, a fried coil may be the culprit... best of luck to you!
all 6 of us agree!!
No new posts VW Volkswagen & Baja Bug General Discussion Center Mount Fan Shroud 4 Darn_Near 3238 Center Mount Fan Shrou...
 Sat Apr 12, 2014 05:13 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion quick help/won't start 5 Pointvirus 3210 quick help/won't start
 Sun Oct 21, 2012 07:42 AM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion hard start relay 4 vwboat 2270 hard start relay
 Wed Oct 17, 2012 10:18 PM
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2915 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion dellorto 36 center mount 2 _-Mad-Max-_ 2736 Re: dellorto 36 center...
 Tue Jun 19, 2012 03:38 PM
