Latest: jor_dang420
Overall: 3597
Visitors: 127
Total: 127
29: Event Calendar
40: Event Calendar
48: Event Calendar
69: Home
71: Event Calendar
75: Event Calendar
79: Event Calendar
91: Pictures
107: My Account
114: Home
116: Home
118: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- California
California
1 2 3 4
elryano
elryano
Post Post subject: Re: California
Posted: Fri Jul 28, 2006 09:20 PM
try going up 1 spline on the torsion bars in the rear will bring you up about two inches i wouldent cut off the stops becuase that would allow the springplates to drop lower than the type 1 joints can handle
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 09:23 PM
so if i get type 2 CV's then i can grind the stops off? and then i can get off road torsion bars and get some more lift...
elryano
elryano
Posted: Fri Jul 28, 2006 09:25 PM
if you wanna go that far id go with 930s
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 09:28 PM
well right now my rear right wheel rubs on my fender when i hit any kind of bump. the guy i bought it from put 31's on there. they are some beefy tires. and there is only 1/2" between the spring plate and the stop when the vw is sitting on the ground not moving. so is 1 notch on the spline going to make it so that i am right on the stop?
elryano
elryano
Posted: Fri Jul 28, 2006 09:45 PM
it might but it will ride better and you will have more ground clearance
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 10:15 PM
to take the drive axles off it uses a 12pt 8mm socket right?
cperry2704
cperry2704
Posted: Fri Jul 28, 2006 11:38 PM
im in carlsbad, ca right south of the military base
72BajaBen
72BajaBen
Posted: Sat Jul 29, 2006 10:49 AM
awesome man...that is right down the street....=]
Posted: Sat Jul 29, 2006 05:19 PM
About there, you may have to compress them to get them in. This is where it gets tricky.
More of a bit than a socket. Why do you need them out?
72BajaBen
72BajaBen
Posted: Sun Jul 30, 2006 06:29 PM
i coldnt get the swing arm out fo the way, i had to take the axle off and it made it a whole lot easier. Im going to adjust them again today. Do anyone know how to adjust the front. or do i need to get front adjusters and weld them in?
Posted: Sun Jul 30, 2006 09:03 PM
cut, turn , and add adjusters to the front
elryano
elryano
Posted: Mon Jul 31, 2006 03:44 AM
you can also just cut and twist the beam dont turn the beam more than a quaeter inch top and bottom
Galvin
Galvin
Posted: Sun Oct 01, 2006 03:17 AM
Huntington Beach !!!
Posted: Sun Oct 01, 2006 04:36 AM
also in the front on the link pin beam you can remove one split stack of springs and replace it with a solid spring. but only do one of the split packs, both is some times too stiff. You will need another link pin beam to get the extra stacks
Dezjunky
Dezjunky
Posted: Sat Oct 21, 2006 11:49 PM
If you're still looking for people in Cali, I'm in the LA county Fairplex area.
No new posts New Members New from California 4 Zack149 3083 New from California
 Thu Oct 08, 2015 08:04 PM
No new posts Events and Get Togethers World Wide The VW Classic-Irvine, California 7 JWHracing 4798 The VW Classic-Irvine,...
 Sun Jun 23, 2013 01:32 PM
Yummi View latest post
No new posts VW Volkswagen & Baja Bug General Discussion New laws passed in the state of California... 7 JWHracing 6146 Re: New laws passed in...
 Mon Jul 30, 2012 05:02 AM
thing View latest post
No new posts We Will Host Your Club Forum here Anyone from the Bay Area, California? 4 zx10r203 4682 Anyone from the Bay Ar...
 Fri Feb 04, 2011 05:05 AM
mikehtiger View latest post
No new posts New Members Hi from foggy California 3 mikehtiger 3075 Re: Hi from foggy Cali...
 Fri Jan 21, 2011 02:45 PM
