Visitors: 160
Total: 160
28: Event Calendar
67: Pictures
95: Event Calendar
116: My Account
123: Event Calendar
157: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Which Adjustable Spring plate for a '73 w/ IRS?!?!
zx10r203
zx10r203
Post Post subject: Which Adjustable Spring plate for a '73 w/ IRS?!?!
Posted: Tue Apr 01, 2008 08:26 PM
How do I know which adjustable spring plate to use with my '73?
There are 30 different sizes!!!
Post Post subject: Re: Which Adjustable Spring plate for a '73 w/ IRS?!?!
Posted: Wed Apr 02, 2008 02:26 AM
Your 73 will have the long torsion bars (tube sticking out of the spring plate covers) and be IRS.
These are the correct ones, unless someone converted to the short torsion bars for tire clearance.
www.chircoestore.com/c...ts_id=2510
zx10r203
zx10r203
Posted: Wed Apr 02, 2008 03:46 AM
No, they do have the long torsion bars still.
Thanks
zx10r203
zx10r203
Posted: Tue Apr 08, 2008 07:23 PM
How much lift can one get from the adjustable spring plate??
Also should I get a new torsion bar? if so which? I see they come in 27mm, 28mm, and 29mm for the 26 9/16 ('73 bug w/ IRS)?!?!?
Posted: Wed Apr 09, 2008 02:50 AM
[quote="zx10r203"]How much lift can one get from the adjustable spring plate??[quote] The lift comes from indexing the spring plates. The adjustment in negligable (sp) in providing lift.
New torsion bars are a good idea as the old ones are 35 yrs old and we ask them to work hard. The diameter you choose should be based on how much weight you stick in the rear, if you go w/longer trailing arms, etc. The thicker the bar, the stiffer the ride and the more weight it can handle. I have 30mm which is probably too thick, but I have 3 x 3's which is harder on the bars and doing a 4 seater with glass, carpet etc. 28 mm is probably the most common upgrade.
No new posts VW Volkswagen & Baja Bug General Discussion can we clarify the ohv/mc/regular plate/park pass stuff? 7 Brettucks 19062 Re: can we clarify the...
 Wed Feb 16, 2011 04:11 AM
Rickman View latest post
2180 Baja bug with 091 trans.
11 51BUG50 3621 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
No new posts Events and Get Togethers World Wide Contemplating a Spring Playday 13 Dirtjunkie 4183 Contemplating a Spring...
 Wed Jan 11, 2017 03:36 PM
No new posts VW Volkswagen & Baja Bug General Discussion Spring Plates 3 Darn_Near 2746 Re: Spring Plates
 Sun Mar 03, 2013 10:12 PM
No new posts VW Volkswagen & Baja Bug General Discussion Fabbed new plate mount and light 9 Tcatdrv 3926 Fabbed new plate mount...
 Sun Jul 04, 2010 07:41 PM
Tcatdrv View latest post
