Visitors: 110
Total: 110
08: Event Calendar
32: Event Calendar
36: Home
50: Event Calendar
55: Event Calendar
100: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Hedrock's 'vert project
1 2 3 ... 7 8 9 ... 14 15 16
The following users give thanks for this topic Anonymous - Tue Mar 17, 2009 12:48 PM
Post Post subject: Re: Hedrock's 'vert project
Posted: Mon Mar 31, 2008 01:12 AM
REAL NASTY!!
Posted: Mon Mar 31, 2008 03:20 AM
Posted: Mon Mar 31, 2008 03:44 AM
THAT THING LOOKS LIKE IT NEEDS A BIG OL NASTY MOTOR!!
I will be acceccting any and all donations... much thanks Wink
ditch68
ditch68
Posted: Mon Mar 31, 2008 05:05 AM
Hedrock, your car gives me nightmares, man! That's my dream, full tube chassis racecar. Absolutely beautiful.
I need to get a dimple form die, I need to make a footrest for my left foot while driving.
Good job!
Jeff
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
Zoom153
Zoom153
Posted: Tue Apr 01, 2008 09:04 PM
That thing is a beauty. Where did you find those awesome rims?
65 Type 11
Posted: Wed Apr 02, 2008 04:01 AM
I bought them on ebay about 2 years ago. Wink
Posted: Wed Apr 02, 2008 04:49 AM
Whatcha going to do with those rear meats? Smile
Posted: Mon Apr 07, 2008 01:17 AM
Another update... I started on some body work today ( I hate body work ) but, I guess it has to be done. Because the heater channels were so rusted out I cut most all of them out ( who need heat Wink ) and replaced them with a piece of 1 1/2x 2" tubing. I had a piece of 3/16 steel bent like a piece of angle thats 3x4" to go from the outside of the square tube to the pan. I will post pics when I get there. I cut the ashtray out and filled the defrost holes and other holes in the dash.
New heater channel...
No more ashtray...
Dash all filled in... I hate body work Rolling Eyes
Now I will work my way back and should be done by next week end.
Very Happy
Posted: Thu Apr 17, 2008 03:12 AM
OK so I'm running behind... What's new? The end of last week turned into the end of this week imagine that Embarassed . After much discussion, debate and pic surf'in this is what I ended up with for the back end. I wanted to cut the back off to look like a class 5 unlimited bug but my sponsor ( wife and brownie maker Wink ) likes the back on. So here are pics of the compromise...
These are at the "a" and "b" pillars by the old heater channels...Think this is a 'vert only item.
Before...
With metal patch...
A little filler...
The back "dash". I wanted to clean it all up
1 1/4" flat stock...
Welded a piece of sheet metal to fill it all in...
The left rear quarter... Before...
Added a filler piece...
View from the top...
Filler for the top...
All done...
A little more welding and some Bondo and this side should be done. Now all I have to do is make the other side match... And order up some more brownies.
One more thing... The profile above the rear fender changed a little when I did all of this. I'll post more pics as I finish more. Wink
Posted: Thu Apr 17, 2008 06:11 AM
do you have any idea how many man hours you have in your baja to date ?
looks good, by the way..... Wink
Posted: Fri Apr 18, 2008 04:17 AM
More progress pics from tonite.
Side view... you can see the little bit the side profile changed. I like it better straight across without the "swoop" down... I think it looks cleaner.
Right side...
Both sides done... What a PITA
Started putting a little "mud" on... Someday it'll be the good kind of mud...
This weekend I should be able to finish the "mud'in" and start back on the frame. If I keep this Blister'in pace up... This thing might actually be done this year Shocked .
Will post more pics soon... Wink
As far as the hours... I guess I never really thought about it. I normally work on it about 5-6 hours at a time then quit for a couple weeks. If I worked on it steady I would have been done a year ago... Rolling Eyes
Posted: Fri Apr 18, 2008 05:27 AM
The little point in the watch out area. I would think it would look better if you cut that section off. I have removed most of that on my baja and think it looks better with out it than with.
Posted: Fri Apr 18, 2008 04:06 PM
I think I will after I mount the fenders. Do you have any pics of yours? Thanks... Cool
Sample
Sample
Posted: Fri Apr 18, 2008 06:14 PM
Is that Century MIG easy to use?
Posted: Fri Apr 18, 2008 08:25 PM
home.earthlink.net/~az...baja_.html here are some pictures.
1170 Dalton 260589 My 69 project
 Wed Dec 06, 2017 01:38 AM
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1256 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 49644 Project II
65 PaDan 47464 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6536 Re: new project
