Visitors: 129
Total: 129
05: Event Calendar
12: Pictures
29: Event Calendar
43: My Account
49: Pictures
59: Event Calendar
60: Event Calendar
64: Event Calendar
72: Event Calendar
75: Event Calendar
77: Pictures
97: Pictures
100: Event Calendar
113: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Hydraulic clutch?
Hydraulic clutch?
zx10r203
zx10r203
Post Post subject: Hydraulic clutch?
Posted: Thu Mar 27, 2008 11:18 PM
Is there any advantages to having a hydraulic clutch?
Pros & cons??
I will be getting new pedals and saw some really nice hydraulic pedals.
Post Post subject: Re: Hydraulic clutch?
Posted: Fri Mar 28, 2008 01:27 AM
I like the fact that the freakin' clutch cable hook (tends to break) is a thing of the past with my hydraulic setup...
zx10r203
zx10r203
Posted: Fri Mar 28, 2008 05:05 AM
how easy is it to adjust adn how reliable is it?
Posted: Fri Mar 28, 2008 05:14 AM
I think it should be more reliable than manual. As for adjustment, I haven't had to do much to it yet, so I can't say for sure. I don't think it's a big deal once you know how to do it though.
Posted: Fri Mar 28, 2008 05:29 PM
As far as Hyd clutches, I pulled the engine and 3 rib installed a 6 rib with new clutch, I hooked up the slave cylinder to the clutch arm and that was it, no bowden tube, no messing with cables, Done!
Reliability depends on the quality of what you buy.
zx10r203
zx10r203
Posted: Fri Mar 28, 2008 07:09 PM
I am looking to get the CNC model. Seen the most of you guys use it and I figured I couldn't go wrong with it.
What type of fluid do you guys use??
Posted: Fri Mar 28, 2008 07:28 PM
DOT 3 Brake fluid. I bought a cheapy slave cylinder and ended up replacing, CNC has been good to go.
planenutz
planenutz
Posted: Fri Mar 28, 2008 07:51 PM
Has anybody tried the silicone brake fluid? Doesn't absorb water and won't peel paint. It can't be mixed with DOT 3 though so using it when installing a new system would be the hot ticket. Cool
zx10r203
zx10r203
Posted: Sat Mar 29, 2008 03:08 AM
I have heard the same thing. I actually useDOT 5 Racing Brake fluid on my motorcycel. From the graphs and charts I have seen the DOT 5 takes a lot to break down and does not heat up as fast.
Posted: Sat Mar 29, 2008 04:38 AM
Whatever you run in your brakes run in your clutch, would suck topping off the fluids and mix the two brake fluids, now what ya gonna do?
zx10r203
zx10r203
Posted: Sat Mar 29, 2008 04:43 AM
Yell, quick scream and pray to the VW gods that hopefully it works!!!!
2180 Baja bug with 091 trans.
11 51BUG50 5140 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
parts
0 bajablastman1214 2544 Clutch
 Sun Aug 16, 2015 05:23 AM
Really bad issues
4 Pointvirus 2746 Clutch Issues
 Mon Dec 03, 2012 07:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 6594 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion clutch ?'s 11 jone$yyy 5093 clutch ?'s
 Thu Apr 22, 2010 06:16 PM
jone$yyy View latest post
