Latest: thelataviayoung
Overall: 3584
Visitors: 170
Total: 170
16: Event Calendar
18: Event Calendar
27: Text Menu
28: Links
29: Memberships
46: Event Calendar
51: Event Calendar
62: My Account
81: My Account
100: Home
108: News Letter
112: Event Calendar
115: Pictures
120: Drivers
136: Home
138: Video Wall
139: Home
140: Event Calendar
147: Pictures
149: Contact Admin
154: Baja Forums
158: Baja Forums
162: Home
164: Baja Forums
166: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- New Front Beams?
New Front Beams?
zx10r203
zx10r203
Post Post subject: New Front Beams?
Posted: Thu Mar 27, 2008 08:10 PM
I am kinda new to Baja and I am building my first one so I can learn as much as possible about it.
Took me a while but found a '73. Got the body off and I am in the process of changing the floorpans.
I have been reading about front ends and I am more confused than ever.
So I have a few questions for you pros:
What is the difference in link pin, king pin, ball joint, and rack and pinion?
Is it worth keeping the current stock ball joint front I have?
If I was to change it, what should I change it to and whats involved??
What parts are needed for the change??
Thanks for the help in advance.
Post Post subject: Re: New Front Beams?
Posted: Thu Mar 27, 2008 10:53 PM
Congrats on your new Baja. Link pins hold the spindle carriers to the trailing arms and allow the up and down movement. King pins hold the spindle to the carrier and allow the frt wheels to turn. This is called a link and king pin frt end.
You have a ball joint front end, where the ball joints take the place of both sets of pins.
Depending on your plans for abuse, the ball joint is usually fine. It is required in some desert racing classes and is stronger in it's stock form. A link/king pin front end has the ability to allow more travel and has great aftermarket help.
To change from ball joint to link pin involves surgery. Most people cut the frame heads off and weld on a link pin frame head; some cut off the frame head completely and hang the beam on tubes; other people modify the frame head and support the beam w/extra tubes; other people buy a conversion beam from Bugzylla; and some people convert to an a-arm frt end with a kit from a-arm.com.
Confused enough yet? if not let me know and I will muddy the water some more. J/K hope that sheds some light.
zx10r203
zx10r203
Posted: Thu Mar 27, 2008 11:04 PM
Thanks for sheding some light on the subject. It definetly helped.
I am not big at abusing. I go to Oceano Dunes (toned down version of Glamis). Not many places around here, but I will probably be relocating in the future. Hopefully somewhere where there is places to drive.
I guess I will keep the b/j front for now and may be in the future change it.
So what are my options in shocks for the ball joint front?? I have not seen many. or what should be used?
Posted: Thu Mar 27, 2008 11:43 PM
Chiro's has a couple to choose from, I think a bus kyb is the best deal.
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2072 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7079 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3234 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 2469 Re: Need Help....Dash ...
 Thu Nov 10, 2011 06:55 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wide Ball Joint front end? 5 Darn_Near 7825 Wide Ball Joint front ...
 Wed Sep 07, 2011 08:12 AM
Darn_Near View latest post
