Latest: slyster
Overall: 3568
Visitors: 261
Total: 261
07: Pictures
29: Pictures
50: Pictures
51: Event Calendar
119: Pictures
133: Event Calendar
157: Baja Forums
166: Baja Forums
171: Baja Forums
173: Baja Forums
176: Baja Forums
179: Baja Forums
181: Baja Forums
189: Baja Forums
190: AMAZON.com
191: Baja Forums
192: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Baja Forums
201: Pictures
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: Baja Forums
212: Baja Forums
213: AMAZON.com
214: Baja Forums
218: AMAZON.com
219: Baja Forums
220: Baja Forums
221: AMAZON.com
224: Event Calendar
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
228: Baja Forums
229: AMAZON.com
230: Baja Forums
231: Baja Forums
232: Baja Forums
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: AMAZON.com
237: Baja Forums
238: AMAZON.com
239: Baja Forums
240: Baja Forums
241: Baja Forums
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: Baja Forums
247: AMAZON.com
248: Baja Forums
249: AMAZON.com
250: Baja Forums
251: Baja Forums
252: AMAZON.com
253: AMAZON.com
254: Baja Forums
255: Baja Forums
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: Baja Forums
261: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- complete 3x3 setup?
complete 3x3 setup?
nube_w_1970baja
nube_w_1970baja
Post Post subject: complete 3x3 setup?
Posted: Wed Mar 26, 2008 03:56 AM
can anyone tell me in full detail just about every nut and bolt and bushing and bearing that i would need to do a 3x3 conversion?
i'ld like to have something to shoot for but get it done right the first time.
any and all help would be greatly appreciated.
good times,
jeff
Post Post subject: Re: complete 3x3 setup?
Posted: Wed Mar 26, 2008 05:52 AM
I've heard some good things about the Beanie Boy kit- I believe it's fairly complete. You plan on going all the way with bus trans and 930 CVs now, or wait until later?
zx10r203
zx10r203
Posted: Wed Mar 26, 2008 09:25 PM
good times,
jeff
Same here, I would like to know what I would need or where can I get the whle kit with bearings, cv's,...
Posted: Wed Mar 26, 2008 09:49 PM
Chirco has a 930 CV kit (different kits for different gearboxes), and then you buy the 3x3 arms from them. Should be pretty much everything you need.
NOT cheap- but you probably already knew that, right? Laughing
Seems like you're going to need to upgrade from T1 CV's in order to benefit at all from the increased travel available with the 3x3 arms. You probably don't need to go ALL the way to 930 CVs, but it certainly would be ideal- do it once and be done, y'know?
zx10r203
zx10r203
Posted: Wed Mar 26, 2008 09:55 PM
I know its not cheap. I will probably finish the Baja and slowly get the 3x3 set up and just bolt it all in when I have it all.
Posted: Thu Mar 27, 2008 01:00 AM
3 x 3 arms pr
trailing arm bushings set
drive flanges pr
drive flange c-clips x 2
drive flange seals x 2
inner drive flange cup seals x 2
cv joints, i used 930's x 4
cv joint flanges x 4
cv joint boots x 4
cv joint bolts x 4 sets
axles for the correct length for your trans
930 conversion stub axles
rear wheel bearings
rear wheel bearing c-clips x 2
rear wheel bearing seal kits x 2
rear wheel bearing spacers if you don't have them
longer ebrake cables if running an ebrake
new brake lines for longer arms
lower shock mounts
upper shock mounts...ie cage
stronger torsion bars to handle the increased leverage
spring plate bushings (since you have it apart)
or instead of the last 2, a coil over conversion package if going coil over.
Did I miss anything?
Posted: Thu Mar 27, 2008 01:49 AM
money, lots-o-money..... Wink Laughing
heres a kit....
www.thesamba.com/vw/cl...?id=263551
nube_w_1970baja
nube_w_1970baja
Posted: Thu Mar 27, 2008 04:16 AM
wow, that's great. so everything would cost around $$$1000$$$ right, maybe some more after shocks...
how hard is it to install?
and i'ld probably stick with the stock tranny.
what is the difference with the busy trannies?
and last, would doing the warrior front beam look too wierd without doing the 3x3's in back first?
good times...
Posted: Thu Mar 27, 2008 06:05 AM
It's about $800 for the CV/axle kit, plus another $375 for the 3x3 arms themselves, THEN you still have to buy shocks. If you wanna add disk brakes, keep going! $$$$
If your car's already IRS, it shouldn't be bad at all- all bolt on, except maybe welding brake caliper mounting tabs to your 3x3 arms if you go disk brakes.
The bus trannies are stronger. Depends on 1) how hard you plan to use/abuse the car, and 2) what type of engine you're planning on running as to whether or not you need to upgrade the trans or not. If you're going with the 3x3 setup, presumably you're going to be running the car fairly hard from time to time, so you may want to consider upgrading the trans to a bus. Also, I may be wrong on this, but I THINK if you're going to upgrade your CVs to either type 2 (bus) or 930, you HAVE to have a bus trans. I think the only CVs you can run with a bug IRS trans are bug CV's, and that's going to cripple your travel with the 3x3s.
That's a matter of opinion, I guess. I don't think it'd be horrible looking...
Posted: Thu Mar 27, 2008 10:32 PM
Tony, you can run 930's w/ a type 1 trans. Just drive flanges.
Posted: Fri Mar 28, 2008 02:46 AM
Very well- I stand corrected. Thanks Don. Confused
No new posts VW Volkswagen & Baja Bug General Discussion Rack and Pinion setup on a Baja bug 3 DFWbaja 2384 Rack and Pinion setup ...
 Fri Jan 30, 2015 01:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja roof height with 3x3 setup 3 ghettodish 2718 Baja roof height with ...
 Wed May 18, 2011 05:17 PM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion shock setup 5 thext94 3944 Re: shock setup
 Wed Apr 14, 2010 02:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion oil cooler setup.. 6 Brettucks 3743 oil cooler setup..
 Tue Feb 09, 2010 02:57 AM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb and intake setup? 11 Torg37 5592 Carb and intake setup?
 Fri Feb 05, 2010 03:26 AM
57baja View latest post
