Latest: Sawmer
Overall: 3609
Visitors: 102
Total: 102
08: Event Calendar
55: Event Calendar
60: Home
61: Home
62: Event Calendar
76: Garage
101: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Baja Trailer??
Baja Trailer??
planenutz
planenutz
Post Post subject: Baja Trailer??
Posted: Mon Mar 24, 2008 10:25 AM
I've got a 1/2 ton 2wd pickup so I can't go crazy on a large trailer (i know, get the Baja on the road first - THEN get a trailer.. Embarassed ) But I was wondering ... can you use a T-type trailer for a Baja or is it too heavy?
(note: not my trailer or rig in the pic - just as an example)
Post Post subject: Re: Baja Trailer??
Posted: Mon Mar 24, 2008 03:47 PM
Just build a small single axle trailer. I have one thats just big enough for a VW and the axle has been set back about a foot farther than normal for equal weight distribution when towing VWs. I have a 1/2 ton 2wd suburban and I have been all over the place with most of the 81 VWs that I have owned in the last few years and it hauls them fine. I have even had a few buses and that didnt drag the truck down too bad either. If you want dimensions and a few pics let me know.
planenutz
planenutz
Posted: Mon Mar 24, 2008 07:36 PM
Pics and dimensions would be cool Very Happy
Another reason I can give my wife why I need a welder! Wink
Thanks Daryl
Instead of offsetting the axle to the rear, could you load the Baja on backwards?
Posted: Tue Mar 25, 2008 02:10 AM
i have a doulbe axle trailer that i pull with my two door tahoe no problem... dont restrict yourself to a small trailer, because down the road you'll wish you had a larger trailer...i know i did...
Posted: Tue Mar 25, 2008 02:56 AM
True
Posted: Tue Mar 25, 2008 03:37 AM
Why not just get a tow bar? Easier on the vehicle your pulling with not having the extra weight to pull plus tow bars are easier to store.
I was thinking like you because I plan to have semi radical tires at least on the rear of my Baja and was worried they'd get worn out from just towing. I decided to keep the skinny tires on if for towing and install the beefy ones when I reach my destination.
My .02c
planenutz
planenutz
Posted: Tue Mar 25, 2008 03:49 AM
[quote="locutisj"]Why not just get a tow bar? Easier on the vehicle your pulling with not having the extra weight to pull plus tow bars are easier to store.quote]
True, I've used a tow bar in the past. My thinking is that every previous time I broke the Baja it wasn't able to be towed so I ended up renting a U-haul. If it breaks back in BFE and I have a trailer I'll be able to haul the carcass out.
Another reason in my convoluted logic is I'd like to get a lightweight pop-up camper for the pickup bed and tow the Baja to wherever we're camping - thinking the weight of the popup and a tadem axle trailer w/Baja may be too much. Anybody tow such a setup with a 1/2 ton automatic? Thoughts?
Posted: Tue Mar 25, 2008 03:56 AM
[quote="planenutz"]
could be pushing it with that set up... Shocked
vwbill
vwbill
Posted: Tue Mar 25, 2008 04:04 AM
I have had by baja to a truck scale weight 830 front axle, 1230 rear, for a total of 2160. I was an even 200 of those. Being the front is so light, I don't see why a "T" trailer wuold not work for starters.
Also check local trailer lots for "PJ" trailer brand. In 2001 I got a new 16' PJ car hauler for $1500. Dealer said he could not build one that cheap. It is licensed for 5999 lbs and weighs 2000.
William
planenutz
planenutz
Posted: Tue Mar 25, 2008 04:05 AM
Would a small single axle and the popup be safe? I don't know what the campers weigh. I don't know what my bug weighs either. Rolling Eyes
Posted: Wed Mar 26, 2008 04:02 PM
Here ya go, just buy this one.
phoenix.craigslist.org...39183.html
zx10r203
zx10r203
Posted: Wed Mar 26, 2008 09:08 PM
[quote="planenutz"]
I am on the same boat as you. I have the baja and a pop up tent trailer. Towing 2 things is going to be an issue since I only have one tow vehicle. The tent trailer weighs close to nothing. When I tow it with my truck (2002 Dodge Ram 1500 4 door 4x4) I even forget its back there due to it being so light. My wifes 2001 Pontiac Sunfire (1.8L 4 cylinder) pulls it.
I was thinking the same thing, getting a 16+ car hauler and mounting the tent trailer on the front and put the baja on the back. I have even considered buying a coach to camp and pull the baja but at $50,000 it is a little out of my range. So now I don't really know what to do.
I wonder if I can hook up the baja to the truck and the trailer to the baja. Road train??? I am sure I could but would definetly get a ticket.
planenutz
planenutz
Posted: Wed Mar 26, 2008 11:05 PM
Dangit, the postings not there now. I have been checking the Tucson Craigslist and the Chirco bulletin board but nothing yet. What did the trailer on Phx criagslist look like?
zx10r203
zx10r203
Posted: Wed Mar 26, 2008 11:14 PM
I just clicked on it and its there.
Craigslist.com listing
planenutz
planenutz
Posted: Wed Mar 26, 2008 11:21 PM
That's why I'm thinking of a popup in the truck bed, like this www.fourwheelcampers.com/
and then the Baja on a small trailer behind. 2k lbs and change for the Baja and a small trailer, and about 1k lbs for the popup in the bed. Might be do-able? Wink Wink
5 Admin_AzBaja 10691 Baja Bugs on Wiki need...
1569 mufasavnvmc 1158898 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 279776 Re: Baja sightings
103 SuburbanLegend 161452 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 2967 FREE VW BAJA'S
