Visitors: 103
Total: 103
03: Pictures
20: Home
32: Home
62: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- New Tubing Bender
New Tubing Bender
Post Post subject: New Tubing Bender
Posted: Mon Mar 24, 2008 07:17 AM
I just bought a new tubing bender yesterday. I bought it at Harbor Freight for $69.99.
Helluva deal, I thought!!!
I've been playing around with trying to make good bends with it and have succeeded in making scrap metal of about 18' of a 20' piece of 1-1/2" tubing. I think I'm getting used to it now, but I thought it would be easier to learn than it's turning out to be. Man, what a learning curve!
I really dig this thing, and should've bought one 15 years ago.
Anyway... I thought I'd share that there are benders out there that are affordable. It would have saved me HOURS of fab time and I can't even imagine what could have been accomplished if I had bought one way back when. The possibilities are endless!
Post Post subject: Re: New Tubing Bender
Posted: Mon Mar 24, 2008 01:57 PM
Send a pic of the bender, I brought home 2 of them and took em back. Its been a while since I have been over there......do they have a new model nowadays?
on hold baja build
"when I nod my head, HIT IT"
Posted: Mon Mar 24, 2008 03:38 PM
If its the orange pie shaped one its not a tubing bender, its a pipe bender. If thats the case you will probably get a bunch of kinks on the inside of the bend and a flat spot on the outside.
Swine
Swine
Posted: Mon Mar 24, 2008 05:05 PM
For $70.... It's a pipe bender. A good tube bender will set you back a bit of change. The pipe dies alone run close to a couple of hundred bucks.
T_Town_Baja
T_Town_Baja
Posted: Mon Mar 24, 2008 05:19 PM
Hey guys, check this one out:
http://www.thesamba.com/vw/classifieds/detail.php?id=542920
Looks like a newer company selling decently priced tubing benders for the average joe garage fabricator. This is very similar to the one I built. I spent $250 for dies and then another $50 for the metal to build it. AND mine looks very similar to this.
I am tempted to sell my bender and pick one of these up.
Blaine
Posted: Mon Mar 24, 2008 05:59 PM
Thats similar to my bender also. Looks like a good deal for only $310
Posted: Tue Mar 25, 2008 01:19 AM
Blaine
Blaine is your bender not working for ya?
on hold baja build
MOCRAWLER417
MOCRAWLER417
Posted: Tue Mar 25, 2008 01:43 AM
I have a pro-tools 105 HD and I really like it. I bought several dies with it and I only have about $1800.00 in it. I also use Bend-Tech software with it. The software has more than paid for itself with the money i've saved by not wasting tubing. Just my .02
Terry Dalton
Posted: Tue Mar 25, 2008 01:59 AM
here's one that im thinking about purchasing.... for 295.00
www.jd2.com/
T_Town_Baja
T_Town_Baja
Posted: Tue Mar 25, 2008 03:03 AM
www.jd2.com/
Read that carefully, I too wanted the JDSquared bender, BUT it does not include dies. The die set is another $250.
Keith -
No the bender works fine, but I am looking for something larger that I can use for more largescale jobs(probly going to switch over to air-over hydrolic or pneumatic). I am also considering picking up the Pro-tools bender (copy of the JDSquared). My dies are pro-tools and I can just pick up the bender for another $275. Just undecided right now.
Here is the link to the pro-tools bender: (same as Mocrawler has)
http://www.pro-tools.com/105.htm
Lates,
Blaine
Posted: Tue Mar 25, 2008 03:27 AM
It's definitely a pipe bender, but the thing works OK for tubing if you massage it a bit. Yea, when you do bends over 45 degrees, it tends to wrinkle the tubing a bit. I found that if you slide the tubing down a half inch or so and crank it, slide it and crank it, slide it and crank it, it seems to make much better bends. I'm not up for spending a couple of grand (or even a few hundy for that matter) for the amount of tubing I need to bend, so this was a pleasant alternative... Heck, I could easily spend 70 bones on beer at a ball game! The beer would've been gone by now, and I still have the bender.
Posted: Tue Mar 25, 2008 03:37 AM
T_Town_Baja wrote:
www.jd2.com/
thanks for the heads up....
so this one is a great deal...... www.tjdieselperformanc...der/Detail
Posted: Tue Mar 25, 2008 01:39 PM
1FASTHOE wrote:
T_Town_Baja wrote:
www.jd2.com/
For 90 degree bends yes its a good deal. Mine was around 7 with 2 dies.
on hold baja build
Posted: Wed Mar 26, 2008 01:35 AM
where'd you buy your's from kc ?
Sample
Sample
Posted: Wed Mar 26, 2008 01:38 AM
I got one of those pipe benders. Building a little buggy/go cart with it and some pipe (oh yikes).
1966 Baja.
No new posts VW Volkswagen & Baja Bug General Discussion tubing notcher recommendations 13 chrispy56 6760 tubing notcher recomme...
 Tue Apr 03, 2012 06:31 PM
brokenparts View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Tubing Bender Information 2 catchbats 1777 Re: Tubing Bender Info...
 Mon May 25, 2009 12:14 AM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Welding Tip For Complex Tubing Angles 5 57baja 2513 Re: Welding Tip For Co...
 Tue Jul 08, 2008 08:22 AM
No new posts VW Volkswagen & Baja Bug General Discussion Roll Cage Tubing Caps 5 57baja 2522 Re: Roll Cage Tubing C...
 Sat Feb 02, 2008 04:31 PM
MOCRAWLER417 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion tube bender in mesa 0 VIN70 1479 tube bender in mesa
 Thu Jun 14, 2007 09:13 PM
VIN70 View latest post
