Latest: xbluegto
Overall: 3573
Visitors: 197
Total: 197
28: Event Calendar
63: Event Calendar
78: Event Calendar
95: Pictures
150: Baja Forums
164: My Account
168: Pictures
170: Baja Forums
172: Baja Forums
173: Event Calendar
174: Pictures
179: Baja Forums
183: Baja Forums
185: Baja Forums
187: Pictures
191: Baja Forums
192: Pictures
195: Baja Forums
197: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Engine Upgrades... HELP PORFAVOR
BajaChick21
BajaChick21
Post Post subject: Engine Upgrades... HELP PORFAVOR
Posted: Thu Mar 06, 2008 10:29 AM
I got a 1600cc I'm thinking about like just upgrading the pistons to an 88mm.... SO I dont even have to tear down the motor all the way ..Or even a higher lift cam.. Any Idears?? Or maybe should I just stay with the way i have it?
I can do Everything a man can do but better!
except for being able to pee standing up I'll leave that to you guys.. =(
Post Post subject: Re: Engine Upgrades... HELP PORFAVOR
Posted: Thu Mar 06, 2008 02:00 PM
Run it till it breaks, put together a rebuild savings, save up for the rebuild.
on hold baja build
"when I nod my head, HIT IT"
Posted: Thu Mar 06, 2008 04:22 PM
I agree with what he said ^^^^^^^. Is it a single or dual-port motor? Hopefully it's a dual-port. When you overhaul it, go with the big-bore AND the cam. What do you have for a carb? That's another potential upgrade. In fact, that may be something you could get some performance improvement out of now with the current motor, and it'd help your new motor as well. Lots of used VW carbs around for reasonable prices...
Oh, and one more thing- PICS PICS PICS PICS PICS!!!!! (of your car) Laughing
dave18
dave18
Posted: Fri Mar 07, 2008 12:02 PM
As they said realy, unless you know someone with a motor that they dont need anymore and then you can strip down and rebuild that thats what im doing.
Rubber side Down,
Kerbs are for mortals,
Who Needs carrots with 12 forward facing lights :D
WWW.BAJACLUB.CO.UK
WWW.DEUTSCHWORKS.COM
Posted: Sat Mar 08, 2008 09:22 AM
You can get a set of 87's and toss 'em in, but you'll get only marginal (at best) gains. I wouldn't do 88's. Like 350 said, get a set of carbs. I've had GREAT luck with Kadrons over the years. If you put on a set of bigger jugs, you may as well port your heads while you have them off, and they will breathe much better than stock. But Bill Fisher's VW book and it will help a TON with that. Talk about FREE horsepower, porting your heads will take many hours of tedious work, but it won't cost you a dime if you have a dremel in your toolbox. A good exhaust system is perhaps the best investment you can make for adding horsepower. On a stock engine, ratio rockers can add a bunch of horses, too.
Stay away from the cam for now. There are much better investments that will give you more bang for your buck and less headaches.
...All of this advice is predicated on the assumption that you have a good strong motor to start with. Otherwise, find a good motor first.
bigsam
bigsam
Posted: Sun Mar 23, 2008 11:52 AM
I,ve herd badthings about 88,s. The cilender walls are too thin and over heat eazy.
DRIVEIT LIKE YOU
STOLE IT
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 361 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 946 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 1573 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 1805 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 3929 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
