Visitors: 103
Total: 103
12: Home
24: Event Calendar
40: Home
48: Home
89: Event Calendar
103: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- No rear floorpan supports??
zx10r203
zx10r203
Post Post subject: No rear floorpan supports??
Posted: Thu Mar 20, 2008 04:27 AM
Well I am in the process of changing the floorpans on my '73. I bought the Bug Me Video on floorpans to show me how to do it since I have never done this before. Well on the video the rear of the floorpan has supports that are welded to the tunnell and the floorpan is tack welded to the tunnell and very little to the supports.
My '73 did not have the supports under the rear of the floorpan. The floorpan seems to the original, all welds look like they came from the factory.
So did the later bugs, at least the '73, not have the supports and were fully welded on the rear to the tunnell for strenght??
zx10r203
zx10r203
Post Post subject: Re: No rear floorpan supports??
Posted: Fri Mar 21, 2008 05:39 AM
I need help!! I have been trying to find out if the '73 has a support under the rear of the floorpan.
I am on the process of putting a new floorpan in and bought the BUG ME VIDEO to give me a better idea of what to do. Now on the video the rear "triangular" section of the floor pan where 2 bolts go through the body on to the pan had a support under it.
I cut most of the pan out and noticed that the rear "triangular" section is fully welded to the tunnell and there is no support under it.
Does anyone know if the '73 had this support under the rear of the floorpan??
Can anyone with a '73 take a picture of the bottom of the rear of the floorpan between the pan and the torsion housing??
Posted: Fri Mar 21, 2008 04:45 PM
zx10,
I've only done floor pans on a 66' and now 68'. Both of those have a hook coming off the rear torsion tube that catches under the pan near the outboard corner and should be welded. Other than that there's nothing else.
I can't imagine a 73' would be different unless some one here can correct me on that.
I can shoot you a pic of that if you need.
Posted: Fri Mar 21, 2008 05:44 PM
zx10,
Look in the Pictures section under Baja's. I labeled the two as Pan support.
zx10r203
zx10r203
Posted: Sat Mar 22, 2008 04:33 PM
locutisj wrote:
zx10,
Thats exactly what I have. Took some pictures last night.
Posted: Sat Mar 22, 2008 09:05 PM
That's about all there is stock. You can add more material for support along the tube and weld to both the pan and the tube as per Jeff Hibbard's "Baja Buga nad Buggies".
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3919 Re: Max angle for rear...
 Fri Jan 29, 2016 05:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2473 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2997 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4342 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
irs,swingaxle
3 desertbaja 3313 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
