Visitors: 194
Total: 194
04: Pictures
27: Pictures
82: Pictures
117: Event Calendar
157: Baja Forums
168: Baja Forums
170: Pictures
186: Baja Forums
190: AMAZON.com
192: Baja Forums
193: Baja Forums
194: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- HELP!!!!!!!!
HELP!!!!!!!!
bigbadbruin
bigbadbruin
Post Post subject: HELP!!!!!!!!
Posted: Sat Jul 29, 2006 06:05 AM
what is the best year to buy if ur turnin into a baja
thanks cody
Post Post subject: Re: HELP!!!!!!!!
Posted: Sat Jul 29, 2006 06:15 AM
There are many schools of thought on this. The best set up is a link pin front end with an IRS rear end. But VW never made it. It is easier to fab a link pin fron to an IRS bug (68 up) but if it needs to go through emissions (evil gov) you should find a pre 67 (66 and older) and convert it to IRS.
Posted: Sat Jul 29, 2006 06:40 AM
I have heard of mexi beetles with link pin fronts, and IRS rears, But never seen one. But otherwise I go for the 66 and earlier and convert them to IRS. Chirco sells the weld in IRS brackets for $25 a set.
Posted: Sat Jul 29, 2006 07:21 AM
Stay away fromthe 67, like mine. You have ball joint front to conver to an link pin and a swing axle to conver to a IRS, not the best choice Smile either side ou only have to convert one end, older is a plus if you stat has emmisons etc.
Posted: Sat Jul 29, 2006 07:41 AM
thanks cody
look at it this way.
here in AZ, if its 1967 or OLDER, there is no emissions. just registration -ccheap too.
so you have 2 ways to be torn now.
in PA, are there emissions exceptions based on year?
Posted: Sat Jul 29, 2006 08:50 AM
Kevin, 67 has to go through emissions also, so its 66 and earlier. I have run many balljoint front ends, and had no problems. But if you want to stay away from a balljoing/swingaxle car, dont buy a 66, 67 or 68. Only the very late 68s had IRS.
72BajaBen
72BajaBen
Posted: Sat Jul 29, 2006 10:54 AM
I have a 72 and i dont have to do emissions in cali....
bigbadbruin
bigbadbruin
Posted: Sat Jul 29, 2006 02:48 PM
thans guys i am going to go look at 2 bugs today im excited
Say10
Say10
Posted: Sat Jul 29, 2006 05:23 PM
Alright whats wrong with a swing axle?
Posted: Sat Jul 29, 2006 05:46 PM
well for one, they are "swingers".
they do not give as much travel, or independant suspension for going over rough terrain.
if one side of the swing is on a rock or hump, the other side is also up removing any drivability. irs allows the "non challenged (excludes me)" wheel to stay on the ground and still power you out of there.
bajasam96
bajasam96
Posted: Sat Jul 29, 2006 10:14 PM
IRS allows your wheel to stay flat on the ground giving you a full contact patch, a swing will hold it on the ground but not flat.
Say10
Say10
Posted: Sat Jul 29, 2006 10:54 PM
Yeah I knew all that I thought there was something else....not as strong, etc....
Say10
Say10
Posted: Sat Jul 29, 2006 10:55 PM
Yeah I knew all that I thought there was something else....not as strong, etc....Did you convert your 59 or is it a "swinger" still (insert Austin Powers joke here if you must)
69bapbaja
69bapbaja
Posted: Sun Jul 30, 2006 06:21 AM
also in sand the swing arm acts like a poll vault around corners the sand buils up pullying the wheel under the car and the force and weight of the car pushed it over.....
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
mohavered
mohavered
Posted: Wed Oct 04, 2006 09:50 PM
hello all, bear with me as i am green on this, i have a 69 i just got and i probally have this swinger axle, how can i tell?, what does irs stand for? what is involved with retro fitting? and what is this link pin device?
