Latest: xbluegto
Overall: 3573
Visitors: 136
Total: 136
16: Event Calendar
53: Pictures
68: Event Calendar
79: Event Calendar
94: Event Calendar
95: Pictures
109: Home
114: My Account
134: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Sagging Rear End
Sagging Rear End
72BajaBen
72BajaBen
Post Post subject: Sagging Rear End
Posted: Fri Jul 28, 2006 09:04 PM
This question is completely unrelated to the first. So I will admit that I dont know alot about VW's, actually I really dont know anyhting at all. But I was reading on how to adjust the rear torsion bars, my rear end is sagging. But when I went to do it last night, the spring plate was only aobut 1/2 inch off of the stop. Is this normal, does the 1/2 inch make that much of a differance? Can I grind that stop off so I can get more lift? Man I have so many questions. Does it sound like my torsion bars need to be replaced because they are streched out? Anything will help me out.
Thanks Again
Post Post subject: Re: Sagging Rear End
Posted: Fri Jul 28, 2006 09:28 PM
Yes 1/2 inch makes a big differance.
And yes you can grind off the stop, but I wouldn't with a stock rear end!
Try turning up the torsions first.
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 09:30 PM
to take the drive axles off i'm going to need a 12pt 8mm socket correct?
Like a star...
Posted: Fri Jul 28, 2006 10:59 PM
try some coil over shocks....
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 11:01 PM
would i have to remove the torsion bars or get special spring plates for that?
Posted: Fri Jul 28, 2006 11:03 PM
coil overs should bolt right into the existing shock locations.
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 11:04 PM
alright thanks. what size...i know its a dumb question but i dont know squat about vw's....yet
Posted: Fri Jul 28, 2006 11:06 PM
get standard vw coil overs. try a VW (preferably a vw off road shop).
check this out....
www.chircoestore.com/c...2f36bd0982
Posted: Fri Jul 28, 2006 11:11 PM
what books do you have on vw?
72BajaBen
72BajaBen
thanks i appreciate it.
Wiggins
Wiggins
Posted: Sat Jul 29, 2006 01:25 AM
Bajafun
Did you get promoted again?
General Manager
www.chirco.com
Posted: Sat Jul 29, 2006 01:52 AM
Wiggins wrote:
Bajafun
to prick second class? no not yet Laughing
72BajaBen
72BajaBen
Posted: Sat Jul 29, 2006 11:04 AM
I have Baja Bugs and Buggies by Jeff Hibbard and How to Rebuild Your Volkswagen air-Cooled Engine (All models, 1961 and up) by Tom Wilson also the hynes book for VW's
Why do you ask?
Posted: Sat Jul 29, 2006 05:00 PM
Why do you ask?
checkin on your reference mat'l Very Happy
Posted: Sat Jul 29, 2006 05:15 PM
Don't mind him, it's just required reading. Laughing
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3050 Re: Max angle for rear...
 Fri Jan 29, 2016 05:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 1786 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2380 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 3724 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
irs,swingaxle
3 desertbaja 2800 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
