Visitors: 107
Total: 107
80: Pictures
82: My Account
84: Home
91: Event Calendar
101: Event Calendar
102: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Replacing the Pan
Replacing the Pan
72BajaBen
72BajaBen
Post Post subject: Replacing the Pan
Posted: Fri Jul 28, 2006 08:57 PM
Hows it going guys. I just bought a 72 Baja. I got it at a steal. It has all the right parts but it was thrown together. Im going to take it down to the pan and put it back together the right way. I also relized that the pan is rusty, and the previous owner fiberglassed over it. Is there a good and cheap way of replacing it. I found pan halves on the net at cip1.com for about 60$ a side. I read in the forum that some one was going to use sheet metal. Is this recommended? I know that you would have to put extra supports in there. So if any one knows of a way that is cheaper than 170$ (2 pan halves and shipping) let me know.
Thanks
Post Post subject: Re: Replacing the Pan
Posted: Fri Jul 28, 2006 09:20 PM
Use the pan halves. They are stronger when they are put in. Flat sheet metal dosen't hold up. Plus you have to fab up seat mounts etc. Just make shure that you can weld sheetmetal and you MUST take the body off to do it right!
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 09:25 PM
Awesome...that i exactually what i was thinking. Im going to take the body off anyway and rebuild it. Redo the wiring, and all the other stuff that is in it. i want to weld some more supports onto my roll cage too.
Thanks again
Posted: Fri Jul 28, 2006 11:01 PM
cip1 is not far from you. see if they have em in stock vs shippin to oceanside.
always try to stay with (close to) oem replacement parts. pan 1/4's and 1'/2's are great!
72BajaBen
72BajaBen
Posted: Fri Jul 28, 2006 11:02 PM
i thought that CIP1 is in washington. where are they located?
Posted: Fri Jul 28, 2006 11:04 PM
disregard, i was under the impression that they had a CA office also... Embarassed
Posted: Sat Jul 29, 2006 06:31 AM
Get them from Chirco, They have quality pan halfs for about $49, and dont rip you off on shipping like other suppliers do.
No new posts VW Volkswagen & Baja Bug General Discussion Replacing air filter
Breather tube?
3 pschneider 3783 Re: Replacing air filt...
 Sun Jun 13, 2010 04:03 PM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Replacing exhaust
compatibility?
7 pschneider 5366 Replacing exhaust
 Mon May 17, 2010 12:37 AM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Advice on replacing glass 4 chickenpants 2030 Advice on replacing gl...
 Wed Nov 04, 2009 03:29 AM
57baja View latest post
