Latest: xbluegto
Overall: 3573
Visitors: 120
Total: 120
10: Pictures
13: Event Calendar
42: Event Calendar
45: My Account
60: Event Calendar
65: Event Calendar
72: Event Calendar
80: Event Calendar
106: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Light Bar Fit Problem
Swine
Swine
Post Post subject: Light Bar Fit Problem
Posted: Wed Mar 12, 2008 09:54 PM
I bought a light bar from Chirco (empi) and if I try and fit it anywhere over the doors... the doors won't open or close. Am I being a total dipwad? (FIE don't answer that) My doors fit almost flush to the drip rail and I would end up grinding off a good part lip that catches the underside. Has anyone else gone through this?
Post Post subject: Re: Light Bar Fit Problem
Posted: Thu Mar 13, 2008 12:24 AM
Ooh- have you called Chirco and talked to Wiggins about it? Are the bars "one size fits all"??
Posted: Thu Mar 13, 2008 01:20 AM
is there more than one way to mount them ? or do they just hook to the drip rail ?
Swine
Swine
Posted: Thu Mar 13, 2008 04:03 AM
Just clamp onto the drip rail as far as I can tell and I've tried to every which way... The space between the door and the drip rail is less than an 1/8". I guess I'll fab something up or mount it behind the doors.
Posted: Thu Mar 13, 2008 05:04 AM
Can you adjust your doors?
Swine
Swine
Posted: Thu Mar 13, 2008 02:36 PM
I'll look...
Posted: Thu Mar 13, 2008 05:34 PM
Sounds like the doors need adjusted like mykul said. I have one on my baja and it fits fine. You should be ablke to loosen the 6 door bolts and drop it down a little, keep in mind you will have to drop the striker plate attached to the body also. Cool
Swine
Swine
Posted: Thu Mar 13, 2008 05:36 PM
I took a closer look at the hinges this morning and it appears like that will do the trick!
Thanks guys....
Swine
Swine
Posted: Mon Mar 17, 2008 06:17 PM
Well moving the door down didn't do much... so I took a hammer and "adjusted" the lip of the door. Perfect Fit! Shocked
Posted: Tue Mar 18, 2008 01:17 AM
THAT'S HOW YOU WORK ON ABAJA!!!! Very Happy
Posted: Wed Mar 19, 2008 09:33 AM
LMAO!
We've all done that at one time or another!
Posted: Wed Mar 19, 2008 03:25 PM
HAMMER IT TO FIT,,PAINT IT TO MATCH!! Laughing Laughing
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 89041 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
what do you use
4 bdrdunes 2380 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 1830 oil light
 Thu May 22, 2014 08:56 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2616 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion I have a problem
Can anyone help me
8 PaDan 5053 Re: I have a problem
 Tue Jul 12, 2011 06:33 AM
Rickman View latest post
