Latest: jor_dang420
Overall: 3597
Visitors: 101
Total: 101
02: Event Calendar
07: Event Calendar
18: Event Calendar
19: Event Calendar
23: My Account
32: Event Calendar
39: My Account
41: Event Calendar
42: Event Calendar
46: Event Calendar
48: My Account
53: Event Calendar
61: Event Calendar
65: Event Calendar
67: Event Calendar
72: Event Calendar
76: Event Calendar
89: Pictures
98: Event Calendar
100: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Front turn signal bulbs
Sample
Sample
Post Post subject: Front turn signal bulbs
Posted: Tue Mar 11, 2008 10:16 PM
I just received the complete front turn signal assemblies that I ordered from Chirco.
The only problem is, they don't have bulbs in them.
What is the part # that I need?
EDIT: Nevermind, I am sure I could just go to the parts store and lookup the bulb for a 66-70 bug.
1966 Baja.
Post Post subject: Re: Front turn signal bulbs
Posted: Tue Mar 11, 2008 10:17 PM
If they are 2 terminal bulbs then you need 1157s.
Sample
Sample
Posted: Tue Mar 11, 2008 11:11 PM
2 terminal?
I have one blue wire coming out of them.
Posted: Wed Mar 12, 2008 12:12 AM
can you pos a pic of them? or a chirco part #?
oldfart
oldfart
Posted: Wed Mar 12, 2008 12:16 AM
external ground?
Sample
Sample
Posted: Wed Mar 12, 2008 01:36 AM
Sure. Hope this works.
Turn Signal Assembly, 64-69 Complete, L/R [CPR113953041J]
www.chircoestore.com/c...lt1tbopmp3
oldfart
oldfart
Posted: Wed Mar 12, 2008 11:05 PM
have you taken off the cover and lens to see where the wires are going? 2 to the socket presumably, and if there is a third.....
Sample
Sample
Posted: Wed Mar 12, 2008 11:25 PM
Just one single wire, through a spring.
oldfart
oldfart
Posted: Thu Mar 13, 2008 12:14 AM
sounds like they are a single filament socket, like a 57 or 67 bulb I think. Just a turn signal, no parklight?
Sample
Sample
Posted: Thu Mar 13, 2008 01:23 AM
These will be used just as turn signals, yes.
Posted: Thu Mar 13, 2008 04:00 AM
RED WIRE TO YOUR FLASHER,WHAT EVER SIDE THEN YOU WILL HAVE TO GROUND THE BODY OF THE LIGHT IF YOU HAVE FIBERGLASS FENDERS, MAYBE THE MOUNTING BOLTS IF THE BASE IS METAL,,
Sample
Sample
Posted: Sat Mar 15, 2008 02:25 AM
They ended up taking 1156 bulbs. Thanks all.
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2365 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7797 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3559 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Its my turn (picture heavy) 7 blubaron66 6143 Re: Its my turn (pictu...
 Thu May 17, 2012 12:24 AM
blubaron66 View latest post
what are yall's set'ups
7 vindeta 14603 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
