Visitors: 100
Total: 100
17: My Account
45: Pictures
51: Event Calendar
95: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- body off
body off
speedtrash
speedtrash
Post Post subject: body off
Posted: Wed Jul 26, 2006 02:54 AM
hey guys, i'm considering taking the body off to clean and do whatever other work that needs to be done. i'm about to start on the bolts now and was wondering what wires need to be removed and where to remove them from. also what should i look for while the body is off? i was thinking about painting the transaxel. would this be a bad idea, and if not what kind of paint can you guys recommend?
carpe diem
"sieze the carpe"
Post Post subject: Re: body off
Posted: Wed Jul 26, 2006 05:09 AM
to be honest with you, and know how most VW's are the wireing is a rats nest. Wires cracking etc. etc. etc. It's not the hard to rewire a VW, I't just like wring a go Kart, just bigger.
I would yank that entire bunch of wires and start over. Use nice heavy wire 10 or 8 for the hot bus and 12 or 14 for every thing else. over build it and you will be real happy with it. If any thing electrical is the ghost in the machine for most people.
speedtrash
speedtrash
Posted: Thu Jul 27, 2006 09:45 AM
i'm not sure i'm gonna be able to get the body off, the first two bolts just broke right off. after that they would just spin but not loosen. i was hoping to start on a cage while i had the body off, but now i'm considering chopping the top off of my perfectly good body. cut out my old floorpans and weld in new sheetmetal instead of new floorpans and just turning her into a custom beater full with a custom spray paint job with SPEEDTRASH on the side in big bold letters( i can see it now!).
carpe diem
"sieze the carpe"
azhunter
azhunter
Posted: Thu Jul 27, 2006 08:18 PM
You can do one of three things here. you can slide a wedge between the body and pan to create space, then sawzall them off. Or, you can drive a wedge or prybar between the pan and body. put pressure on the bolts and then try to back them out. Or, chop it up and continue as you stated above....good luck to ya. Very Happy
Posted: Thu Jul 27, 2006 09:08 PM
I had to helicoil 10 or 11 body bolts on BugZyla. A suggestion, Soak them in penetrating oil for a day or so, then heat the bolt up with a torch and it should come out.
Posted: Thu Jul 27, 2006 09:10 PM
why did you helicoil body bolts? dont they all go straight through to the under side?
azhunter
azhunter
Posted: Thu Jul 27, 2006 09:51 PM
I highlyreccomend ZEPRESERVE NC penetrating oil. works better than WD-40. I use it all the time on Turbo and exhaust bolts.
Posted: Thu Jul 27, 2006 11:16 PM
The body bolts are threaded into the body itself. When I took them out a bunch broke off, even though I heated them and used penetrating oil on them. So after drilling out the broken bolts, I helicoiled them.
speedtrash
speedtrash
Posted: Fri Jul 28, 2006 12:58 AM
well i've got all the bolts out except the for two (i think) so far only two have broken, but i think the last two are gonna break too.
carpe diem
"sieze the carpe"
Posted: Fri Jul 28, 2006 05:41 AM
what the heck is it and where do you get it ? (zepreserve)
azhunter
azhunter
Posted: Fri Jul 28, 2006 05:03 PM
Do a web search for ZEP chemicals in texas. Or check your local yellow pages. ZEP is the manufacturing company.
speedtrash
speedtrash
Posted: Fri Jul 28, 2006 10:16 PM
one bolt broke and one came right out. but my problem now is that i never took out my steering wheel i jammed a screwdriver into the locking cylinder and couldn't get it to turn, so my column is locked up.
how do i get my column unhooked? i noticed that mesh part of the assembly is attatched at the top by just a simple clamp setup, should i bend the clamps out?
carpe diem
"sieze the carpe"
speedtrash
speedtrash
Posted: Sun Jul 30, 2006 01:44 AM
i got the body off. where can i buy good quality floorpans?
carpe diem
"sieze the carpe"
Posted: Sun Jul 30, 2006 02:17 AM
chirco.com
azhunter
azhunter
Posted: Sun Jul 30, 2006 02:40 AM
www.chirco.com is a favorite store amongst us..but do to what youre wanting and the size of it. I'd do a web search for a local(texas) off road baja shop as freight can be monsterous for big items. You might also try www.thesamba.com too. you can norrow down your area in the search button. check for new vendors and used too Good luck to ya....Get ya a dig. camera too. we need pics Very Happy
25 Kreed 26226 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 4395 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Body Lifts 2 Darn_Near 2612 Re: Body Lifts
 Sun May 12, 2013 08:24 AM
1974 baja build
4 mkingaz 3897 Stretched pan and body
 Mon May 14, 2012 08:49 PM
mkingaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2357 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
