Latest: hulkbaja
Overall: 3594
Visitors: 110
Total: 110
09: My Account
17: Pictures
25: Home
44: Garage
45: Event Calendar
49: Home
50: Home
81: Pictures
84: Links
93: Drivers
102: Home
106: My Account
109: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Test Your VW Knowledge
Post Post subject: Test Your VW Knowledge
Posted: Mon Mar 10, 2008 05:44 AM
I was looking for a particular VW part in my garage today, and while looking through boxes of stuff, I happened to think that it might be fun to take a picture of some of the things I ran across and see if anyone could recognize them all. Here's the test:
Good luck
Post Post subject: Re: Test Your VW Knowledge
Posted: Mon Mar 10, 2008 06:05 AM
1. Door handle trim?
4. Clutch cable wing nut
9. Rocker stud
10. Rocker clip
12. Thow out bearing clip
15. Rocker shims
Now that I got the easyones out of the way Daryll can school us.
Posted: Mon Mar 10, 2008 06:07 AM
3. Body washer?
Posted: Mon Mar 10, 2008 06:14 AM
Mykul: five correct minus two for two wrong answers
3 Points given
Some of these are easy and some are pretty damn hard.
Posted: Mon Mar 10, 2008 06:20 AM
2. Engine mount nut
6. acclerator (SP?) pump spring
fatalifeaten
fatalifeaten
Posted: Mon Mar 10, 2008 07:05 AM
1. Outer door rubber
2. Case nut (the big ones)
3. Gas tank hold down
5. No clue
6. Acc pump spring
7. throttle cable pin for the carb end (where the cable gets passed through the linkage)
8. no clue, looks like something off a carb.
9. Rocker Stud
10 rocker clip
11 rocker shaft c-clip
12 evil evil t/o bearing clip
13 eluding me right now
14 gen pulley nut,
15 dizzy drive shims
--Harlan Ellison
Posted: Mon Mar 10, 2008 07:29 AM
Mykul: +1, -1... Still 3 points
fatalifeaten: 7 correct, 5 incorrect
2 points given (although an impressive showing)
Mykul is in the lead.
Posted: Mon Mar 10, 2008 07:36 AM
The trick is to quit when your ahead, it's like Vagas.
fatalifeaten
fatalifeaten
Posted: Mon Mar 10, 2008 07:43 AM
dangit, 13's gonna bug me until I remember what it is. I've seen it, and I think I've had to replace it. Now to remember where.
--Harlan Ellison
Posted: Mon Mar 10, 2008 07:46 AM
CARB LINKAGE, BUSHING? (13)OFF CARB
Posted: Mon Mar 10, 2008 07:54 AM
Updated score:
Mykul: 3
fatalifeaten: 2
jamesr6168: -1
This is kinda fun actually.
fatalifeaten
fatalifeaten
Posted: Mon Mar 10, 2008 07:55 AM
That's what I'm thinking. I was gonna go look, but not until morning.
--Harlan Ellison
BajaChick21
BajaChick21
Posted: Mon Mar 10, 2008 09:54 AM
oooo THis is a Tuffy... It doesn't show these things in hoe to keep my v-dub alive... LOL
Posted: Mon Mar 10, 2008 03:40 PM
OK here we go. Not sure on a few items because I cant tell the sizing from the pic but I will give it a shot.
1 Door Handle Trim
2 looks like an 8mm 1.25 nut to hold on the rocker arms or case bolt
3 Looks like the washer from the back side of a dash for an oh crap handle or padded dash.
4 Clutch cable wing nut.
5 Is a bolt/nut safety retainer, not sure if its supposed to be bent or not but if not then I would guess for the steering rag joint.
6 accelerator pump spring
7 Is a plug for the un used lights on the back of a speedo
8 Is either a throttle shaft from a solex or part of a wiper transmission
9 Rocker Stud
10 Rocker Arm Clip
11 Emergency brake pivot clip
12 Throw out bearing clip (easy to install if you own a small pair of vice grips)
13 not sure, can we get a clue on size and what its made from? is it white plastic?
14 Wiper transmission nut (just under wiper arm)
15 Distibutor drive shims
Posted: Tue Mar 11, 2008 03:50 AM
I certainly figured you'd be one of the better contenders BugZ, and you proved me right. You got a some of the tougher ones. You even got one of the ones I considered to be next to impossible!
10 correct, 4 incorrect
6 Points given.
(NEW CHIP LEADER)
Nice job.
#13 CLARIFICATION: It is white plastic or nylon. The clue on size is that all of these items were taken in the same photo. Therefore, it is relative in proportion to all of the other items.
No new posts VW Volkswagen & Baja Bug General Discussion Felix Baumgartner test drives the Volkswagen XL1 0 trev0006 2708 Felix Baumgartner test...
 Fri Mar 08, 2013 08:37 AM
No new posts VW Volkswagen & Baja Bug General Discussion !st mini test drive 6 Brettucks 3127 Re: !st mini test driv...
 Sat Mar 06, 2010 06:25 AM
Preston View latest post
No new posts VW Volkswagen & Baja Bug General Discussion They do it every time. (Rails for sale test) 12 perrib 10094 Re: They do it every t...
 Sun Nov 15, 2009 12:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion JWH Racing trailing arm beta test. 5 perrib 4602 JWH Racing trailing ar...
 Fri Jul 31, 2009 06:19 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Go Pro Video Camera Test part 1
Go Pro and The Rolls part 1
2 perrib 1414 Go Pro Video Camera Te...
 Mon Jan 12, 2009 12:13 PM
