Visitors: 117
Total: 117
11: Event Calendar
19: Event Calendar
31: Event Calendar
93: Pictures
107: Event Calendar
Leatherneck's rail
Posted: Tue Mar 04, 2008 05:51 AM
OR SOME UNDER ROOS! Laughing
Posted: Tue Mar 04, 2008 10:52 PM
Did some exhaust matching, probably could of opened it up a little more but with the pressure did not want to push it.
Also cleaned out the end castings to help flow alittle.
Here is what I have so far.
Posted: Wed Mar 05, 2008 12:50 AM
Looking good Leather......LET IT BREATH
on hold baja build
"when I nod my head, HIT IT"
Posted: Wed Mar 05, 2008 07:28 PM
Hope you guys don't mind the pics but wanted to add what to the build.
First I wanted to put it on the lift to so I could work on it eaiser, Sorry for the dark pictures..
When I got it up I found this, so off with the head and fix this while it is easy to get to.
Posted: Thu Mar 06, 2008 02:19 AM
Keep the pics coming, we like pics.
on hold baja build
Posted: Thu Mar 06, 2008 06:09 AM
How soon 'till that baby's purrrrrrrr'in Cool
Posted: Thu Mar 06, 2008 06:19 AM
She don't purr Wink
VIN70
VIN70
Posted: Fri Mar 07, 2008 05:22 AM
mmmm shiny! how did you secure those super cool tins??
Posted: Fri Mar 07, 2008 08:21 AM
Wish I had that much room to work on stuff.
Posted: Sun Mar 23, 2008 01:44 AM
Getting ready to stab it in.
I switched from a 3 rib to 6 rib and did some work on the tranny mount so it was a female dog to get in, talking with Hedrock he suggested drilling the bottom hole just to make sure there was no hang ups, did that, put alittle more tilt on it and fits like a .... well it fit good.
Some more messing around
Finally time for the fun part to go on.
Still have to figure out a home for the intercooler.
here is what I have.
Probably should of gone with 2" tubing glad I didn't go with the 3" Looks ok! Be better when finished.
Posted: Sun Mar 23, 2008 01:50 AM
did you ever get the bugs worked out of it ?
lets hear it run..... Cool
Posted: Sun Mar 23, 2008 02:11 AM
Don't know, pretty sure I do but still have to hook up the LM-1 and get some engine readings. Have to break in the rings and then I can play. Here it is second start up after oil change. So far start up is pretty quick, we will see how it lasts.
Posted: Sun Mar 23, 2008 02:20 AM
sounds like you cured your erratic idle.....
doesn't have the same pop as seabees...... Laughing Laughing
Posted: Mon Mar 24, 2008 12:08 AM
Just got back from my ring break in *giggle*giggle* if I wasn't so cold I would be jumping around and patting myself on the back. One word " Strong" good goggley moogley she has some power, have a problem though, builds boost to quick Laughing love problems like that. Didn't bring it over 2900 rpms and maybe 10lbs boost, I know I said I wasn't at all but Laughing Laughing Laughing I varied the speed up and down on the throttle putting a load on it as much as possible. have some oil leaks, go figure, not concerned with them. I am happy, have some adjustments to do but I am happy Very Happy
Posted: Mon Mar 24, 2008 12:13 AM
No new posts VW Volkswagen & Baja Bug General Discussion My VW Rail vacation 13 azdesertrat87 5848 Re: My VW Rail vacatio...
 Mon Jul 22, 2013 07:32 PM
30 dogknott 22313 another newb, just bou...
 Sun Jun 26, 2011 06:11 PM
dogknott View latest post
No new posts VW Volkswagen & Baja Bug General Discussion So you think your rail flys??? 1 perrib 1760 So you think your rail...
 Wed Jan 26, 2011 05:06 AM
thext94 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front tires on a rail 1 Vipon 1377 Re: front tires on a r...
 Wed Jun 16, 2010 02:51 AM
No new posts Projects and Builds Rail resurrection 4 Thingster 2627 Re: Rail resurrection
 Thu May 13, 2010 01:45 AM
Thingster View latest post
