Latest: hulkbaja
Overall: 3594
Visitors: 115
Total: 115
34: My Account
39: Event Calendar
45: Pictures
47: My Account
57: Pictures
59: Pictures
61: Event Calendar
64: My Account
87: Pictures
103: Home
107: Pictures
114: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- need info on brake drums
clovismike
clovismike
Post Post subject: need info on brake drums
Posted: Tue Mar 04, 2008 05:24 PM
howdy all,,my 69 baja has five hole lugs ,are all drums the same as far as bearings and spindles?
when i hauled my bug home one brake locked up and burned the shoes ,drum got real hot
now im looking to get new drums for now ,,plan on getting a disk brake set up,
car was almost ready to start on fire it was so hot,,are the four hole hubs the same?? thanks
oldfart
oldfart
Post Post subject: Re: need info on brake drums
Posted: Tue Mar 04, 2008 05:33 PM
bugzyla can give you better info than I, been a loooooong time for me. but, do you have a spacer,say 1/2" or so, between the rear drum and the axle nut? You could be running 66/67 front and rears from same, or T3 if the shoes are wider, or a Thing. Step in bugzyla, great master of all things baja....
clovismike
clovismike
Posted: Tue Mar 04, 2008 05:56 PM
good question,,,i havent taken it apart since i got it home,,took hot drum and the brakes apart on a mountain top,,so didnt really look,,im going to take it all apart this weekend ,,thanks
Posted: Tue Mar 04, 2008 08:03 PM
Post a pic of the rear drum. You can use early drums but you have to put a spacer on between the drum and the nut. Otherwise you need Thing rear drums.
oldfart
oldfart
Posted: Tue Mar 04, 2008 11:35 PM
Daryl what was the deal again on T3 rear drums? I recall the increased shoe surface, but don't remember the particulars on using spacers with T3 drums, swapping axle lengths etc...I've ran 5lug on irs with spacers, and ran T3 drums on swing bugs, but forget the formula for mixing both on irs
clovismike
clovismike
Posted: Wed Mar 05, 2008 12:40 AM
would it be the same on the front ,,its the front one im going to fix??? thanks,,mike
1 LittleBaja 2380 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2233 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3223 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
24 vwboat 11181 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
No new posts New Members New guy in Arizona needs info
Looking at buying my first bug
8 TattooedIrish 3708 New guy in Arizona nee...
 Fri Sep 14, 2012 09:52 PM
