Latest: BlackIrish05009
Overall: 3574
Visitors: 134
Total: 134
03: My Account
23: My Account
24: Pictures
31: My Account
32: Event Calendar
51: Pictures
53: Event Calendar
56: Pictures
65: My Account
84: Event Calendar
95: Pictures
109: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- trans mount.
trans mount.
shpuz
shpuz
Post Post subject: trans mount.
Posted: Tue Mar 04, 2008 06:01 AM
well, im getting ready to replace my worn out front mount with a solid front mount. the rear mount is already a solid, previous owner was just apparently too lazy to do the front one. what would be the best way to do that? i dont want to take the engine and trans out, i would like to figure out a way to leave everything in while i change it out. is that possable? any tips would be helpfull.... thanks guys.
Quote::
shpuz
shpuz
Post Post subject: Re: trans mount.
Posted: Tue Mar 04, 2008 08:37 AM
any one have any advice?
BAJABUGNUT
BAJABUGNUT
Posted: Tue Mar 04, 2008 10:09 AM
SHPUZ,
I am new here and by no means an expert but I do have some skilz and have been around for awhile.
If ya got the tools and skills fab one up, I did and before that had never done it before, actually I fabbed up the whole bus box mount with urethane mounts. Its not all that hard just measure everything at least 5 times.
If you have the mount already just jack it up and lay under the carl, look at it till it comes to you on how it can be done.
If you plan on fabing one up yourself just poke around for tranny mounts and you will get plenty of ideas.
hope this helps.
Thin blue Line, Your About to Taste Liquid Hell
shpuz
shpuz
Posted: Tue Mar 04, 2008 10:51 AM
yeah, i already have the part. i never thought about fabing one up. i guess ill just go lay under the bug for a while and see what i can do. haha.
Posted: Tue Mar 04, 2008 01:47 PM
Its going to be tight working, there is no easy way with everything in place. My advice is get the car up on ramps throw your tools under there and start. Put a jack under the front of the tranny to hold it as you remove the old mount. Cuss alot, use lock nuts as you finish. Then when you are all done share the tips and tricks you came up with.
on hold baja build
"when I nod my head, HIT IT"
oldfart
oldfart
Posted: Tue Mar 04, 2008 11:43 PM
it is possible to change the mount without pulling the trans, but it's a knuckle buster. You have to pull the front nose cone with it. Take off the mount bolts,nose cone bolts and pull tilt tug the 2 off as a unit. Been about 20 years since I did it, can't recall if you have to do anything else like kick it into a certain gear or not. Course you have to unhook the shift rod under the rear seat. Reinstall with a solid should be a piece of cake, less bulk.
I'm assuming you aren't gonna mind the vibration, increased noise from solid mounts. You'll get used to it. I drove my 65 baja from Phoenix to Boise with solids, full cage,6" widened beam, glass buckets, no long lasting effects except my butt still tickles Wink
shpuz
shpuz
Posted: Wed Mar 05, 2008 01:02 AM
nah, extra noise dosnt bother me at all. if i can handle straight headers on my 390 v8 at 3,000 RPM for 200 miles, i can pretty much handle anything. haha.
Posted: Wed Mar 05, 2008 02:21 AM
just a idea, what about cutting a acess hole from the interior ?
that way if you ever need to work on the tranny or shift rod you have a easy way to get at it....
Posted: Wed Mar 05, 2008 04:43 AM
i think mine has an accses panell
could be wrong tho...
oldfart
oldfart
Posted: Wed Mar 05, 2008 05:22 PM
you'd have to cut it throught the floor of the rear cargo area, but all you'd access is the top of the tranny, clutch tube, etc....not much you can do from up there without having to still go underneath. It does help (access wise) to trim the lower lip of the body off even with this cargo floor area...you can reach in easier but you're more vulnerable to mud, rain and snow. Nothing like changing a clutch cable in a foot of snow...been there.
No new posts VW Volkswagen & Baja Bug General Discussion Center Mount Fan Shroud 4 Darn_Near 2795 Center Mount Fan Shrou...
 Sat Apr 12, 2014 05:13 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2588 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion dellorto 36 center mount 2 _-Mad-Max-_ 2433 Re: dellorto 36 center...
 Tue Jun 19, 2012 03:38 PM
No new posts VW Volkswagen & Baja Bug General Discussion Changing over to 3-rib bus trans... maybe? 10 planenutz 4999 Changing over to 3-rib...
 Wed Jan 18, 2012 09:20 AM
planenutz View latest post
17 TwistedMetal 12665 Which trans with a 22r...
 Mon Dec 05, 2011 02:51 AM
chrispy56 View latest post
