Visitors: 98
Total: 98
11: Home
19: My Account
20: Event Calendar
41: Event Calendar
52: Contact Admin
63: My Account
77: Event Calendar
79: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- no power
no power
blood_red_baja
blood_red_baja
Post Post subject: no power
Posted: Mon Mar 03, 2008 06:57 PM
ok after our last ip out i started blowin fuses, i replaced them yesterday, but i still have no electric, the battery is fully charged but nuthin. is this a common thing with bugs?
twistedsmily
twistedsmily
Post Post subject: Re: no power
Posted: Mon Mar 03, 2008 09:19 PM
sounds like you need to replace a wire or two, just my .2
Posted: Mon Mar 03, 2008 09:20 PM
Are they the same fuses popping over and over, or random ones?
blood_red_baja
blood_red_baja
Posted: Mon Mar 03, 2008 11:57 PM
um over and over, but the last 2 random
oldfart
oldfart
Posted: Tue Mar 04, 2008 12:18 AM
Assuming you have a stock harness and switches, I'd first look at the wiring on the headlight switch, the heavy red ones first...touching perhaps? Then I'd suspect the ignition switch, but only after checking every connection, need more info on your setup
blood_red_baja
blood_red_baja
Posted: Tue Mar 04, 2008 12:45 AM
69 bug stock, but a baja. over and over the wiring twice, started random and i do believe stock wiring harness; replaced fuel cell to fuel gauge wire, i dont see the common link between the two.
Sample
Sample
Posted: Tue Mar 04, 2008 01:47 AM
I am confused.
1966 Baja.
blood_red_baja
blood_red_baja
Posted: Tue Mar 04, 2008 03:13 AM
Would the fact that I added two off road lights to my baja have this kind of affect? The headlight fuse was the first to go. So tomorrow I will re-run the wiring and double check to make sure nothing is touching, but I don't think there is.
Posted: Tue Mar 04, 2008 04:13 AM
SHOULD BE RUNNIG A RELAY ON THE OFFROAD LIGHTS ON THEIR OWN CIRCUIT,,IF THERE ARE ANY WATTS TO THEM,,,,
oldfart
oldfart
Posted: Tue Mar 04, 2008 11:45 PM
disconnect the new lights. fuses still blow? if not, there's your problem.
sounds like you have a power wire grounding out.
Posted: Thu Mar 06, 2008 07:41 AM
are you bringing your baja up to the pizza meet on the 15th? if so i'll take a look at your setup, i have been dealing with my electrical crap for about a month now and i've gotten it all squared away, i'd be happy to help you out!
NOTE: It's usually something you wouldn't think of... been down that road, got a flat and lost a nut... Wink
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 9519 Cheap DIY electric pow...
 Fri Nov 06, 2015 02:07 AM
No new posts New Members I don't have VW power, is that okay? 7 AZBadseed 5841 Re: I don't have VW po...
 Wed Sep 07, 2011 11:52 PM
AZBadseed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion PROJECT FLOWER POWER!
39 crickifur 18146 Re: PROJECT FLOWER POW...
 Sat Dec 04, 2010 06:33 AM
No new posts VW Volkswagen & Baja Bug General Discussion baja power troubles 10 bajaboy 6091 Re: baja power trouble...
 Mon Sep 15, 2008 07:13 PM
70bug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion more power and where? 9 nube_w_1970baja 2997 Re: more power and whe...
 Thu Nov 01, 2007 06:05 PM
