Visitors: 136
Total: 136
11: Event Calendar
23: Event Calendar
36: Pictures
71: Event Calendar
96: Event Calendar
110: Pictures
114: Pictures
120: Home
121: Pictures
126: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Which bus tranny to get?
Billy
Billy
Post Post subject: Which bus tranny to get?
Posted: Thu Feb 28, 2008 05:26 AM
So i've read that the 5 rib is the best. Why is that? What is the gearing on it? I have also heard of a 6 rib somewhere, once. Typo perhaps? Once the weather gets better I am going to swap my tranny to a bus one. I also want to know the best way of going about doing it. So far I am interested in what this article has to say:
www.stormseeker.org/VW...rsion.html
Post Post subject: Re: Which bus tranny to get?
Posted: Thu Feb 28, 2008 06:03 AM
There are 3 bus IRS transaxles that are desirable for off road use. The 3 rib 002 was the first one and production started in 1968 and went through 72?, then there was the 5 rib 002 in 73-74? and this was a stronger trans, the 3rd is the 6 rib 091 trans, the strongest and most desirable made from 75-77? The 78 & up 091s were side shift and cant be easily converted so stay away from them.
meangreen
meangreen
Posted: Thu Feb 28, 2008 06:12 AM
sounds like the kit to have to me,when i got my 3 rib i jerked out the old tranny,built me some solide mounts,and then used a bug axle that had been machined to fit bus cv's on the inside,bolted it in....at this point DO NOT DO WHAT I DID,IT WAS JUST TO GET ME A "FEW" DAYS.... then i cut a 5 inch long 2 inch wide hole in front of where the tranny linkedge meets the shift shaft,cut like 2 inches outa my shift shaft,then welded in a "custome" flex joint.......a 3/8 wobble joint from a stanley tool set....then made a support plate for this awful contrapshion i had concockted and then drove it........ beleave it or not it actually workd.but yea i'd say get that kit,then have a good time changin out trannyz....it realy isnt that hard tho.i could do it on my lunch break....dont ask how i no that....i just didn have time to work at home....and its true it wasnt guna hurt to miss a meal or 2
planenutz
planenutz
Posted: Thu Feb 28, 2008 04:05 PM
Which brings up a question:
I have a stock bug trans and since my baja is still in work in my garage I shouldn't be breaking it anytime soon. Rolling Eyes
But if I ran across a bus trans, what is an average good deal price that a person shouldn't pass up?
Billy
Billy
Posted: Thu Feb 28, 2008 10:38 PM
I am going to get a rebuilt one for whatever price I can get. The last thing I want to do is buy a lemon tranny and put it in and have to do everything over again.
Posted: Fri Feb 29, 2008 02:55 AM
i bought mine from a guy in tempe for 200 bucks, then had it rebuilt.
go with aztrans or dons bus box...
nukeworker
nukeworker
Posted: Fri Feb 29, 2008 03:41 PM
If you buy a used one, I'd just put it in and try it out before rebuilding. They're real easy to remove and install. So's the engine. You might find out it works fine and save yourself the rebuild cost for a couple hours work.
nukeworker
nukeworker
Posted: Fri Feb 29, 2008 03:43 PM
If you buy a used one, I'd just put it in and try it out before rebuilding. They're real easy to remove and install. So's the engine. You might find out it works fine and save yourself the rebuild cost for a couple hours work. I would first drain the oil out and replace with new while it's out. Easier that way.
nukeworker
nukeworker
Posted: Fri Feb 29, 2008 03:46 PM
Sorry for the double post. Tried to edit the first one, now can't get rid of it.
No new posts VW Volkswagen & Baja Bug General Discussion Please help ID this tranny 4 albee 3161 Re: Please help ID thi...
 Mon Dec 23, 2013 03:51 PM
No new posts VW Volkswagen & Baja Bug General Discussion Swing axle tranny -> IRS tranny 1 Spudman 1378 Re: Swing axle tranny ...
 Sun May 03, 2009 09:58 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need swingaxle tranny! 2 bajabro 1558 Re: Need swingaxle tra...
 Tue Apr 28, 2009 11:24 PM
bajabro View latest post
No new posts VW Volkswagen & Baja Bug General Discussion HELP HELP! 2.0L type 4 in a 65 swingaxle tranny?!?!
will my 1979 2000cc type 4 motor fit in any swingaxle tranny
4 Petersonhotrodfactory 2284 Re: HELP HELP! 2.0L ty...
 Mon Mar 16, 2009 04:26 AM
Petersonhotrodfactory View latest post
No new posts VW Volkswagen & Baja Bug General Discussion newbie with tranny question! 5 soopercoop 2547 Re: newbie with tranny...
 Sun Feb 25, 2007 11:25 PM
soopercoop View latest post
