Visitors: 167
Total: 167
03: Pictures
114: Pictures
142: Pictures
144: Event Calendar
158: Baja Forums
162: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Gunna buy some new tool's......
meangreen
meangreen
Post Post subject: Gunna buy some new tool's......
Posted: Thu Feb 28, 2008 03:53 AM
ok as i have already said,i am planning a new baja project...i am goin to pick up a tubing bender,new chop saw,and get my bottles filled when i get home,and as always when i buy a new tool i have to "test it out" wich usually turns into a year long project.....but anyway i am wanting to build a a-arm setup like the "bolt on" one being discussed her on azbaja......i was just wondering,what size heim jouints should i use,this car is goin to be a dailydriver/weekend warrior kina thing,so it is not gunna be jummping dunes/lakes,rivers,houses ? anyway u get the idea....just need an idea on the joints needed,and what is the proper "rake" in degreez for a a-arm setup ?so's not to have "bump steer"....and how do i decide how to place my shoks ?like what angle/where at on the arm.any help would be great,i promise to keep ya'll up to date,if i get enuff info to get this off the ground
Sample
Sample
Post Post subject: Re: Gunna buy some new tool's......
Posted: Fri Feb 29, 2008 01:35 AM
Sounds like fun, but if you won't be doing any "jummping dunes/lakes,rivers,houses " why do you need the a-arm setup? Don't get me wrong, I would really like them too.
1966 Baja.
Posted: Fri Feb 29, 2008 01:41 AM
Yea, whats the point of a arms if your not goin to use them
I guess you could get em just to say you got em
Posted: Fri Feb 29, 2008 02:50 AM
There are sooooooooooooooooo many threads on the a-arm subject. Everyone has an idea and a question. If you look around you will find pictures of some funky attempts at the a arm and you will find some class road proven suspensions built by people who have been at it a long time. On "TOS" you can find alot of discusion and not much action on the subject. If "I" was to go this route I will rely on a racer that builds and drives his design. Race Awards Page
on hold baja build
"when I nod my head, HIT IT"
meangreen
meangreen
Posted: Fri Feb 29, 2008 05:10 AM
man azbaja site is havn issues,i posted erlyer and it came up a white page and said somen bout a an formating error,and had som emumbo jumbo in list form...anyway i will be jumping the car just not for a while,wanna see how it all turns out b4 i jump the grand canion u know ?i will be jumping water bars,railroad traks,and mybe some "sand bumps" at Quachita lake,wich is near where i live....any way what size heims i need ?
Posted: Fri Feb 29, 2008 12:51 PM
Here is a picture of A-Arms set up looks good.
on hold baja build
Posted: Fri Feb 29, 2008 03:37 PM
Interesting how he put adjusters on the limiting straps, and it even looks like there's still a piece of the beam incorporated into the design.
Posted: Fri Feb 29, 2008 08:40 PM
The adjuster "clevis" is to take up the slack in the limit strap as it stretches. SDHQ sells them for ~27.00 each; about the same as McKenzie's.
The beam is there so it can be bolted into a stockish Baja. It is a very well thought out deal.
Posted: Fri Feb 29, 2008 08:48 PM
That is a sweet set-up, Pete does great work that is for sure. Trying to get something going on a how to for the do-it-yourselfer . We will see how it pans out.
meangreen
meangreen
Posted: Sat Mar 01, 2008 02:58 AM
i have all the tools i need i'm sure and can get what i dont have,but just looking at the setup above,i can't tell that there is any rake at all to the setup,i was under the impression that u had to have your suspention tilting slitly bak so that the suspention was "shoked" away from the bump thus eliminating what we no as "bump steer"......other than needing to no what size heims i need i think i could totaly pull this off.....i mean everyone had to start somewhere rite ? BLC guys didn just wake up one morning knowing how to build lifted spindals,cages,4x5's,and all the other trick stuff they do...did they ? but i really wanna have a go at this so if its at all possibal,drop me a few pointers,or if u no of a road blok i'm gunna have....warm me.....i dont want a "hand out" just a helping hand....untill next time thanks azbaja and all its members
Posted: Sat Mar 01, 2008 04:06 AM
your beam is tilted back, about 6 or 7 degrees..i just checked mine...
meangreen
meangreen
Posted: Sat Mar 01, 2008 05:18 AM
so u think that would be enuff tilt to let the tires arch over the bump instead of get jolted by it ?if so i just gotta get hom eand get started that was my biggest concern.....ya'll think 1 1/2 inch 120. wall would be about rite ? i think thats what has been used for most stuff like this.thanx 1fasthoe you didn have to go do all that....but it really did help...
69baja69
69baja69
Posted: Sat Jan 21, 2012 07:13 PM
Ima build this on my baja, mi got all the heims, mine are aircraft heims 2 inch
No new posts Projects and Builds Tool
Plz help
2 Zack149 1932 Re: Tool
 Sat Jul 11, 2015 05:36 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tool 2 kcnaz 1704 Re: Tool
 Sat Jan 26, 2008 06:03 PM
kcnaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Spring plate tool 9 az350x 3608 Re: Spring plate tool
 Tue Jan 08, 2008 01:17 AM
DONT View latest post
