Visitors: 100
Total: 100
16: Memberships
59: Event Calendar
64: Links
65: Event Calendar
67: Event Calendar
78: Home
80: Pictures
84: Pictures
94: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Gas tank question
Gas tank question
neon99
neon99
Post Post subject: Gas tank question
Posted: Thu Feb 28, 2008 09:14 PM
Is it normal for the gas tank to create a vacume to the point that when I take off the gas cap I get a big whooshing sound of the air getting sucked in? Also any ideas on why an ignition coil would get hot to the touch? I am so close to havin the car run and drive but can't get it to idle and I'm wondering if these 2 things have anything to do with it... THANKS
ditch68
ditch68
Post Post subject: Re: Gas tank question
Posted: Thu Feb 28, 2008 09:19 PM
You can get a vented cap to solve the fuel tank problem. That could affect fuel supply in extreme cases.
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
fatalifeaten
fatalifeaten
Posted: Thu Feb 28, 2008 10:13 PM
I've seen it frequently in early nonvented tanks.
--Harlan Ellison
cperry2704
cperry2704
Posted: Thu Feb 28, 2008 11:42 PM
my coil was getting hot to the touch, ended up i had a 6v coil on my 12v system
neon99
neon99
Posted: Thu Feb 28, 2008 11:47 PM
I will take the cap off and see if it will help it run !! and a new coil will get put on and hopefully this thing will run!!!
Posted: Fri Feb 29, 2008 03:20 AM
You need to make sure you have a ballest ristor in line with the coil or the coil has a built in ballest.
It's that white chalky looking thing.
a coil is just a spool of wire and the ballest is the load (Light bulb, motor etc.)
So a quick how it works if you take a spool of wire hook it to your pos and neg battery terminals at the same time the coil of wire will get real hot etc. and burn up, it's a bad thing. your coil is like that coil of wire. put a light bulb in the section of wire you get light and the wire stays cool as the light bulb is a restive load or ballest on the wire.
if you can mout the coil terminals up. so the cooling oil can cool the coil of wire inside the coil. never mount a coil upside down or evan on it's side, it's bad for the coil.
wazhier
wazhier
Posted: Fri Feb 29, 2008 03:25 AM
maybe you should just give it back to the "so called"friend who gave it to you! jk lets get it running!!!!!!!!!!!11
neon99
neon99
Posted: Fri Feb 29, 2008 06:01 AM
AZBAJA, do you have a pic of the resister or where I could get one? Right now the wire comes directly from the ignition swith to the coil, and then the wire from the dizzy conects to it and thats it.. If the coil has a built in
ballist how would I tell?
Posted: Fri Feb 29, 2008 07:28 AM
www.azbaja.com/Forums/...istor.html
images.google.com/imag...a=N&tab=wi
this should help. I also bumped the 2 topics.
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 7922 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2661 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5476 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3455 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4375 super baja question
 Thu Aug 29, 2013 11:07 PM
