Visitors: 165
Total: 165
02: Event Calendar
04: My Account
06: My Account
07: My Account
20: Pictures
80: Event Calendar
84: My Account
101: Pictures
145: Event Calendar
150: Baja Forums
154: Baja Forums
157: Baja Forums
158: Baja Forums
162: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How to: Floorboards
How to: Floorboards
Post Post subject: How to: Floorboards
Posted: Fri Feb 29, 2008 01:47 AM
Im just wondering if You can make custom floor boards just out of sheet metal, and do you have to take the body off?
If you look in my project(rust bucket baja) you can tell how much rust i have. I will be working on this hopefully march 17 in a heated garage, to april 17, any help app. thanks
Post Post subject: Re: How to: Floorboards
Posted: Fri Feb 29, 2008 02:40 AM
would be quicker to order full pans rather than hit and miss with fabbing something up. It fits....as far as having to lift the body up I do not know.My body was off when I did mine.
on hold baja build
"when I nod my head, HIT IT"
FlyinBLS
FlyinBLS
Posted: Fri Feb 29, 2008 02:49 AM
If you use a flat piece of sheetmetal it won't be nearly as strong as a stock type floor pan. The floor of any vehicle acts as a sheer plate (the loads & forces act on it in all directions).
I'm not saying you can't do it but, you will need to add a lot of bracing to get that strength back.
'69 Bug rolling shell (not yet cut for Baja)
'90 Mustang, 2.3l (~300hp/300tq turbo transplant in progress)
'78 B-600 NASCAR PARTY BARGE
MOCRAWLER417
MOCRAWLER417
Posted: Fri Feb 29, 2008 03:44 AM
You could take a flat piece of sheet metal and use a dimple die and spend several days dimpling the sheet metal. Then take another flat piece of sheet and weld it to the backside of your dimpled sheet. It would be a lot stronger ,but I would just buy new pans and do it that way.
Terry Dalton
Billy
Billy
Posted: Fri Feb 29, 2008 06:09 AM
If you buy new pans you don't have to take the body off, but life will be so much easier and its not that hard. That's what I did. Putting in new pans is not as hard as people make it out to be as long as you take your time and do a good job.
zx10r203
zx10r203
Posted: Tue Mar 04, 2008 07:27 PM
I'm working on changing my floor pans as we speak. Seems like mine are welded all the way around. I bought the BUG ME video on the floopans and it was a lot of help!
