Visitors: 125
Total: 125
13: Pictures
61: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- MOCRAWLER'S 68' Baja project
MOCRAWLER417
MOCRAWLER417
Post Post subject: MOCRAWLER'S 68' Baja project
Posted: Sun Feb 24, 2008 02:52 AM
Here are the pics of what I am starting out with. Hopefully I will have pics with lots of progress very soon.
Terry Dalton
VIN70
VIN70
Post Post subject: Re: MOCRAWLER'S 68' Baja project
Posted: Sun Feb 24, 2008 03:13 AM
what will you be ending with???
joxracing2
joxracing2
Posted: Sun Feb 24, 2008 04:26 AM
wow, i wish i had something like that to start with. the blue one in the background looks just as good.
Starting baja project this summer
16 yrs old
Posted: Sun Feb 24, 2008 06:13 AM
Nice Score, looks high maintenance though
Posted: Sun Feb 24, 2008 06:23 AM
[quote="VIN70"]
somebodys caught!!
MOCRAWLER417
MOCRAWLER417
Posted: Sun Feb 24, 2008 06:35 AM
Not too high. Very Happy It's worth it.
Terry Dalton
Posted: Sun Feb 24, 2008 06:41 AM
If I didn't already have a ride I would ride it too.
Well anyway, what are your plans for engine,suspension, well everything, what parts do you have? Time to get busy now.
MOCRAWLER417
MOCRAWLER417
Posted: Sun Feb 24, 2008 07:03 AM
I got after it tonight. First thing was to clean out the interior. The floor looks pretty good. I am debating whether or not to replace the pan. The rear area of the passenger side has a couple of small holes in it.
I removed the engine block from the tranny. The clutch felt like it was working well. The brakes work too.
I think the clutch on my other motor must be a different kind. It looks totally different.
The pedal area looks good. The moisture is from the tow home in the ice.
I started removing extra wiring and I removed the lights from the roof.
I also took a pic of the other rear side window. Some serious etching went on here. Shocked
A shot of the dash.
Terry Dalton
joxracing2
joxracing2
Posted: Mon Feb 25, 2008 02:45 AM
do you think it is a good idea to put in a radio or and kind of music in your VW?
16 yrs old
MOCRAWLER417
MOCRAWLER417
Posted: Mon Feb 25, 2008 04:31 AM
I took advantage of the cold weather today and stayed in the shop to get this thing stripped. Whoever had this before me was really into self tapping sheetmetal screws. I found a big problem when I removed the hood.
Yes, that's 1/2" steel strap welded to the head. Geez, Overkill!!! Still it's broken.
I think i'm going to run new wires. These wires go every which way. Mostly in circles. Very Happy
Last was the sawzall...... Now it's starting to look like the baja i'm hoping for.
I spent a few hours removing the seats and using a propane torch to dry the floor ,then brushing it with a wire brush to removed the dirt and rust,.
Terry Dalton
Posted: Mon Feb 25, 2008 05:11 AM
Are you going to pull the body off the pan? That frame head looks spooky!
Posted: Mon Feb 25, 2008 05:25 AM
Need to figure a way to get this 69 out there to ya...the whole car. Anyone going that way.
on hold baja build
"when I nod my head, HIT IT"
MOCRAWLER417
MOCRAWLER417
Posted: Mon Feb 25, 2008 05:28 AM
I'm not sure. I'm going to definitely get a new head frame. Do I need to take the body off to replace it?
Terry Dalton
MOCRAWLER417
MOCRAWLER417
Posted: Mon Feb 25, 2008 05:31 AM
That would be nice Very Happy
Terry Dalton
Posted: Mon Feb 25, 2008 01:52 PM
I would pull the body if it was my project, I found that my rear torsion was bent after removing the body. With that much damage up front I would want to see the rest up close. My bro-inlaw is gonna be out here around Easter, let me chat with him about getting you a pan. He owns a trucking outfit.
on hold baja build
5 Admin_AzBaja 7381 Baja Bugs on Wiki need...
1568 mufasavnvmc 1021364 Re: what did you do to...
285 MusicManiac 246612 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 496 FREE VW BAJA'S
1199 Dalton 351890 My 69 project
