Visitors: 102
Total: 102
11: Event Calendar
26: Event Calendar
29: Event Calendar
40: Pictures
86: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Exhaust help
Exhaust help
Post Post subject: Exhaust help
Posted: Sun Feb 24, 2008 07:24 AM
This is my exhaust:
As you can see i have working heater boxes.
The problem: I need an exhaust system that can be connected to my heater boxes, AND, Have the "stinger" stick UP not out.
so i'm pretty much looking for this exhaust system, or a "J" ( 90*) Bend tube to use on Chirco's models so i can have my stinger pipe sticking up.
anyone got a 90* tube with triangular 3 hole mounts?
... didn't think so Rolling Eyes
so if anyone knows where to get this type of exhaust system, or if anyone can fabricate the "J" bend for Chirco's models let me know Wink
this is the Chirco model i am considering, which i will add the J bend to:
Post Post subject: Re: Exhaust help
Posted: Sun Feb 24, 2008 09:02 AM
buy the one with the stinger up and take it down to a muffler shop and fit it to the heater boxes.
If madhatters mufflers is still around. I used to take real odd stuff into them and they would fix me up.
DutchBug
DutchBug
Posted: Sun Feb 24, 2008 11:56 AM
The ones without heater boxes often have the J-pipe runnning on the side of the head instead of underneath so rebuilding for heater boxes is a pipebending job.
I had one on my old stinger but the bend was way to tight which choked the engine. Make sure you get the pipe diameters right.
Posted: Sun Feb 24, 2008 03:03 PM
Call Chirco and tell them you want a Baja header you can use with heater boxes and they will hook you up. The chirco header you have a pic of is for a street car.
tucsontim
tucsontim
Posted: Sun Feb 24, 2008 04:08 PM
You can also cut and re-weld the stinger so that it is vertical. (If'n you find a system similar to yours with the provision for heater boxes.)
No new posts VW Volkswagen & Baja Bug General Discussion Exhaust 7 sandbuggy 3713 Re: Exhaust
 Sun Nov 17, 2013 12:15 AM
No new posts VW Volkswagen & Baja Bug General Discussion thunderbird H4207 - 4 Pipe Chrome exhaust
question for owners/ viewers of particular exhaust
13 beachmaster 8120 thunderbird H4207 - 4 ...
 Tue Nov 29, 2011 01:57 AM
beachmaster View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VW baja bug Exhaust options? 4 71VeeDub 7648 Re: VW baja bug Exhaus...
 Sun Nov 27, 2011 03:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Replacing exhaust
compatibility?
7 pschneider 5291 Replacing exhaust
 Mon May 17, 2010 12:37 AM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Difference between exhaust systems?
competition vs standard?
3 pschneider 2423 Difference between exh...
 Mon Apr 19, 2010 09:32 PM
Freeloader587 View latest post
