Visitors: 124
Total: 124
26: Home
43: My Account
46: Event Calendar
47: Event Calendar
110: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bfg tires
bfg tires
texbroker
texbroker
Post Post subject: bfg tires
Posted: Sun Jul 23, 2006 05:00 AM
What would be the best size tires for the rear of my baja, iam thinking of 31's or 32" bfg mt. I just need to know if the 32 will fit or if it will rub on the irs torsion bar, any help would be great ..
thank you
jerimiah
us army retired
69bapbaja
69bapbaja
Post Post subject: Re: bfg tires
Posted: Sun Jul 23, 2006 05:43 AM
I run 31's and they have exactly one inch of play. SSSooo I say 31' are it for ya.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
azhunter
azhunter
Posted: Sun Jul 23, 2006 06:06 AM
My bug has 31's and have about 1 in. clearance too. Ya don't want to push it. Keep in mind, the larger the tire, the taller final gearing you have.
Posted: Sun Jul 23, 2006 06:12 AM
32s will rub. Go with 31s.
Crash
Crash
Posted: Sun Jul 23, 2006 09:19 AM
I have 36" tires but mine is a bit different...
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Posted: Sun Jul 23, 2006 10:19 AM
31x10.5 on 15 is the normal tire size for most Baja's. Not to big to rub or over work the engine.
Posted: Mon Jul 24, 2006 12:41 AM
you might want to think about what gears your running in your tranny.... i have 30's on my buggy, remember the taller the tire, the slower your going to be, in other words, you'll lose torque....
speedtrash
speedtrash
Posted: Mon Jul 24, 2006 12:52 AM
the bigger your tire the higher your top speed will be. but bigger and wider tires means your not able to peel out as easily as small thin tires.
the first thing i'm gonna do when my beetle runs is get some stock tires and tear em apart!
carpe diem
"sieze the carpe"
BajaMark
BajaMark
Posted: Mon Jul 24, 2006 04:41 AM
OK Now what size for the front . I see a lot of different sizes but I like the tall narrow ones.
Mark. Manxclub,RBC,Arizona Baja
Posted: Mon Jul 24, 2006 05:00 AM
fronts:
either stock 165/15 metric
i run 215/ 85/ 15 for more clearance
BajaMark
BajaMark
Posted: Mon Jul 24, 2006 05:10 AM
Well something like the centerline wheels with M/T tires you know?
Say10
Say10
Posted: Mon Jul 24, 2006 05:31 AM
I run 215/75r15 Remington all terrains in the front, and i have about 13-13.5 inches of clearance in the front and run (like everyone else) 31-10.5r15s in the rear. What kind of drivin r u doin? I would stick with a good all terrain rather than a MT. The tread wont wear as fast and youll have less road noise, if it matters. just my 2 cents...
BajaMark
BajaMark
Posted: Mon Jul 24, 2006 05:42 AM
Thanks for the advise. Actually I ain't driv'n it yet. It is under construction. More questions will be comming.
Posted: Mon Jul 24, 2006 05:46 AM
Tire wear relly is not a problem I have had the same BFG M/T's on the back of my baja now for seven years. Still have well over a 1/2 of ruber on them. And the car was a daily driver. I'm looking to replace them do to tire rot and cracks starting to show up in them.
Say10
Say10
Posted: Mon Jul 24, 2006 05:56 AM
Yeah i had MTs on a Bronco I had and they were great, just heard that MTs had a tendency to wear faster but as always each expeience is different with things.
68 Baja Beetle project build
5 Scrappy68 3405 Re: Lets talk tires.
 Fri Dec 14, 2018 03:45 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 2580 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
vw baja stock tires
7 iBeastSousa 4209 tires
 Tue May 27, 2014 10:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3541 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
25 Rigger 12754 I am looking for some ...
 Fri Oct 05, 2012 03:30 AM
Rigger View latest post
